10-14-2017 13:09 - edited 03-21-2018 10:28
I've been notified that there are reports of One battery draining quickly on iOS version 2.41.1 and our team is currently investigating. If you are experiencing this, we recommend disabling all-day-sync for now. I'll update this post once I hear more. Thanks as always for your patience and understanding.
Actively managing your weight? Find accountability buddies on the Manage Weight board
01-08-2018 08:26
01-08-2018 08:26
Update on Fitbit One charge. I had to recharge my One this morning after my walk. The last time was December 24. It stayed charged for over 15 full days. I think that is the longest ever. So happy the problem has been solved. Hopefully everyone has been as lucky and hopefully it continues.
@suefit5 wrote:I charged my Fitbit One overnight after 11 full days since last charge. I had received the email telling me it was time to recharge but when I put it to charge it was still showing some battery life yet. Lets hope this continues. I can't believe it ... a Christmas present to me I guess. lol. Merry Christmas every one ... hope your Fitbit One's are working better also.
01-08-2018 14:30
01-08-2018 14:30
01-08-2018 15:16
01-08-2018 15:16
@sandybeatty @suefit5 as you report successful battery use, can you tell if your devices were upgraded to the last firmware (v6.64, released at fall)?
I had a battery failure (not lasting more than a day) after having done that upgrade upgrade. It could be a rare coincidence with the device "end of life". So I bought a new One device (paid more that it used to be) still on stock but it is with v6.60 and I am now reluctant to upgrade it after my bad experience.
01-08-2018 17:33
01-08-2018 17:33
01-08-2018 17:46
01-08-2018 17:46
01-12-2018 23:06
01-12-2018 23:06
I am incredibly frustrated about the lack of response from Fitbit about this issue.
I reported ten days ago that my fitbit wasn't holding its charge. Despite reassurances from Fitbit that they were working to resolve the issue and would email me when it was resolved, I have heard nothing.
My Fitbit is now unusable as it drains (from fully charged) in an hour!
I have rung twice, and emailed three times, about this. Each time I am assured that a fix is being worked on but in the meantime (ten days and counting) I have an unusable Fitbit.
Do you have any idea if there has been any progress in relation to this?
Is there anyone else I can speak with, if you don't know?
Many thanks,
Liz (Nakasendo43)
01-13-2018 06:31
01-13-2018 06:31
have you read the forum and done any of the suggested solutions written by other ONE owners? What solutions have you tried?
01-13-2018 13:54
01-13-2018 13:54
01-13-2018 14:33
01-13-2018 14:33
01-13-2018 14:39
01-13-2018 14:39
01-13-2018 16:13
01-13-2018 16:13
Thanks again for the replies.
This is the latest email I have received from Fitbit (just 30 minutes ago):
"Hello Liz,
Thank you for updating us on your case.
Our engineer team is still working to resolve this issue as soon as possible.
In the mean time, we recommend that you sync your device with a different operative system such as Android or perhaps your computer. This could be a good workaround until our team finds a proper solution.
We appreciate your patience. Let us know if you've additional questions."
Their recommendation to sync with a 'different operative system' is a bit insulting given that I've repeatedly explained to them (five times now - via phone calls and emails) that I have access only to a Mac computer and an iPhone.
My app version says it's 64, but there is no capacity to update beyond this when I go into my account. That is; there is no 'pink update button' appearing. I noted on the Fitbit help page that I 'will only see an option to update my device if an update is available.' So I am assuming there is no option to further update. Certainly in my converstations and emails with Fitbit they have not suggested this as a possible solution.
Thanks again for replying, I may be wrong, but this community appears to be taking more of a genuine interest in the issue than people working for Fitbit. Sigh!
01-13-2018 16:48
01-13-2018 16:48
Hi Liz. I also have a Mac and iPhone. Someone on here was kind enough to explain to me how to find out the version. Go into your iPhone app and go into the 'Dashboard'. There is a little 'Account icon' at the top right corner. Touch it and your 'Account' will open up. Scroll down to 'Help'. When you go in the 'Help' it shows you the version # at the top. Mine is 2.44.2 (739). I was having the same problems as you and now the last charge lasted 15 days.
I updated my ONE, turned the All Day Sync off, and even set my ONE so that I only see the steps. Then I charged it (connected to my Mac). When it was charged I left it plugged in and held down the button until FITBIT came up on the screen ... that resets it. I have had two long charges since then so it seems to have fixed it. I don't know if it was the combination of all I did or the update.
Hope this helps. Good Luck.
Susan
01-13-2018 16:54
01-13-2018 16:54
Hi Liz ... another thing. If you go in the App Store on your iPhone the updates will be there to download.
Good Luck again,
Susan
01-14-2018 00:35
01-14-2018 00:35
Thanks so much, Susan - I really appreciate you taking the time to explain all of that.
I've followed the steps - and I am already using 2.44.2 (739) according to my Fitbit.
It's great that that worked for you though.
Thanks again,
Liz 🙂
01-14-2018 04:13
01-14-2018 04:13
Hi again Liz. One other thing I did was to stop using the Fitbit Dashboard. I use only the app on my iPhone. It seemed to take a long time to sync on the Dashboard and I thought maybe that was helping to drain the One.
One more question, when did you last reboot your One? I did mine about a month ago. I had done it before and it didn't help. I was thinking maybe it was an update from around the middle of December that solved the problem. Maybe another reboot would do the trick.
A friend was having problems with her ONE also and she has a Windows computer and no phone. After the updates from December we rebooted hers and it is also working well now. Another friend was not so lucky as it will not even charge or reboot ... completely blank. But, hers was quite a few years old. She gave up and bought another product.
Hopefully it will be solved for you soon. I know how frustrating it is.
Have a good day,
Susan
01-14-2018 12:39
01-14-2018 12:39
Hi Susan,
My One bit the dust after a late 2017 update. I’m attempting all your suggestions as I write this, but it won’t even charge now.
I bought a Fitbit Alta, not wanting anything on my wrist but still wanting to keep my fitness goals. I am getting used to it, but miss my One every single day, especially the stair counter. I also bought a third party magnets clip that is good for when I don’t want to use the wristband.
Im so gladness your One continues to work! Happy Stepping!
01-14-2018 12:56
01-14-2018 12:56
Hi Susan,
Thanks for your continued suggestions - they are much appreciated.
I've had a number of email exchanges with Fitbit and after trying all of their attempted 'fixes' I have just received this email from them:
"Thank you for updating us on your Fitbit One case.
We really appreciate all the troubleshooting that you've done so far regarding your tracker. This last step, which was syncing your One with a different device has led us to believe that the tracker's battery is defective rather than a syncing issue.
The most we want, is to have you walking around with a perfect tracker. Therefore, in order to better assist you and investigate all the options that we have for you, please provide us with:
I'm hoping this means that they are going to replace my Fitbit. It is not holding a charge at all anymore, despite following all of their, and your, suggestions. Fingers crossed it is, as they now suspect, a defective battery -- and that they are going to replace it.
Sorry to hear that you are also having problems Cullzer. You may want to call and/or email Fitbit directly (as I've been doing for the last twelve days) to see if they are able to assist?
Thanks again for the all the assistance you have offered, Susan.
Liz 🙂
01-14-2018 13:25
01-14-2018 13:25
01-14-2018 13:30
01-14-2018 13:30
01-16-2018 12:47
01-16-2018 12:47
It is not the all day sync that is the issue. Anytime you sync it goes down to zero on the battery, even after a full charge.
