01-07-2016 15:42
01-07-2016 15:42
01-09-2016 14:39
01-09-2016 20:26
01-09-2016 20:26
My One quit syncing January 7th. Why is that? It won't sync, and the dongle can't locate the One on any device (2 computers and my phone).
01-10-2016 03:25
01-10-2016 03:25
Hi @Bob17. Welcome to the Community. It could be a number of things, but the first thing I would do is restart it, using the instructions in this link: Restart.
Hope this helps. Please let us know how it goes.
TW
____________________________________________________________________________
(If this tip solved the problem for you, please mark this post solved, as this will be helpful to other users experiencing similar issues.)
01-10-2016 06:16
01-10-2016 06:16
01-10-2016 10:50
01-10-2016 10:50
My syncing stopped on the 8th Jan (NZ time). Restarting has not fixed the problem! What to do?
01-10-2016 12:23
01-10-2016 12:23
I've just experienced this issue with the android mobile app, but when I removed and reinserted the dongle it updated the dashboard on both the desktop and mobile app. Hope this helps.
01-10-2016 13:18
01-10-2016 13:18
This is a solution if you have a Mac running the El Capitan operating running the El Capital OS. Whenever you reboot, you have to remove and reinsert the dongle. This iws a known glitch with the El Capitaan OS. Apparently either Mac or Apple is working to fix the issue.
01-10-2016 19:51 - edited 01-10-2016 19:59
My FB One has not been able to sync since 12/24/15... I have reset it many times, redownloaded my app, tried everything you guys have suggested... and still nothing I either get that my phone cannot find the tracker or my phone cannot sync with fitbit.com... and my school deleted my desktop app and when I went to redownload it, the error came up that it could not find my tracker again... I really don't have the money to buy a new one... and it is getting really annoying because I am starting a new job at the end of the week and I want to see my activity level.
Oh, I have and android and a PC windows 7
01-11-2016 03:37
01-11-2016 03:37
Hi @EquineGirl105.
Please try this:
TW
01-11-2016 04:20
01-11-2016 04:20
my fitbit has stopped tracking. done everything suggested.
all it says is Looking ....
so annoying. i can not keep up todate and take part in Challeges with friends.
01-11-2016 06:01
01-11-2016 06:01
Having the exact same problem -- have done all the resets, reinstalls, etc. Has anyone heard anything -- are they aware of the problem, working on it??
01-11-2016 06:04
01-11-2016 06:04
Still waiting. Clearly a FitBit problem but AFAIK no response/solution from Company.
(BTW, appears to be One specific, have a Flex that seems to work/sync OK)
01-11-2016 10:35
01-11-2016 10:35
No problem to report at my end. The One is tracking normally.
TW
01-11-2016 10:46
01-11-2016 10:46
I did this and it did not work.
01-11-2016 10:53
01-11-2016 10:53
@JackieLL wrote:I did this and it did not work.
It would be helpful @JackieLL to indicate what 'this' is referring to.
TW
01-11-2016 11:01
01-11-2016 11:01
I was replying to a previous post where the writer mentioned restarting his ONE according to the directions provided. I've basically tried everything I can read that everyone has done.
01-11-2016 11:04
01-11-2016 11:04
Hi @JackieLL. Do you know for sure that the restart was successful? If successful, you should have seen the fibit logo and firmware version show up on your One's display - Fitbit 6.60. If you didn't get to see that on your screen, please restart your One again, two or three times if need be, until you do see Fitbit 6.60. Please hold the button longer than the 10 seconds advocated in the Help document; I would suggest holding the button down 15-20 seconds if need be.
TW
01-11-2016 12:25 - edited 01-11-2016 12:26
I'm having the same problem. Mine hasn't been able to sync since January 6. I thought it was because of the battery, so I plugged it up with the dongle cord and got it to 100%. Still won't sync. Called customer support, they said that because my One isn't under warranty anymore they can't help me, but they'd gladly sell me another one at a 25% discount. I told her this one works fine, it's just not syncing with anything. We went through the restart process and my computer doesn't recognize the dongle cord. Strange isn't it? It charges the One, but it doesn't recognize it when I want to sync? Hmmm, new marketing technique for the new year?
01-11-2016 12:43
01-11-2016 12:43
Hi @shell6269. For your Fitbit One tracker to sync with your computer, you need the USB dongle to be plugged into a USB port on your computer.
This is the dongle: . The other gadget with the wire hanging is for charging your Fitbit One only.
TW
01-11-2016 13:52
01-11-2016 13:52
My Fitbit One is working, but the app on my Iphone is not synching with the device. I have closed out of the app on phone and turned the phone off several times. It was working fine on Sunday 1/10/16. With all the other posts one would guess this is not user error, but a system problem.
