01-07-2016 15:42
01-07-2016 15:42
03-15-2016 20:50
03-15-2016 20:50
My "one" stopped sync'ing 2 days ago, right after I ran update Apps in iTunes and sync'd my iphone 6.
I've tried turning the phone on & off several times. I've deleted the app and reinstalled. I
In addition, I've tried syncing to my Mac, and that hasn't worked either.
Nothing's working. Very frustrating. Any other suggestions?
03-16-2016 08:42
03-16-2016 08:42
Hi @danimac. Have you tried any of the tips included in I can't sync my tracker ? Quite often, all it takes to restore the sync functionality with your phone is to turn Bluetooth OFF and back ON after 20 seconds or so (you may have to repeat the process two or three times if need be). Fitbit also uses single-channel Bluetooth technology in all its trackers, such that you can only have a live connection to one device at a time. So you may want to sign off your account on your Mac prior to attempting to sync with your IP6.
Hope this helps. Please let us know how it work.
TW
03-16-2016 13:57
03-16-2016 13:57
03-16-2016 17:06
03-16-2016 17:06
Hey @danimac, glad everything is back to normal, Take care!
TW
05-15-2016 05:25
05-15-2016 05:25
Guys, i have switched to Microsoft wrist band and its awesome. Fitbit has the the world cheapest bluetooth ever. My 12$ bluetooth winter cap bluetooth works far better than fitbit.
They couldn't even fix the app for runnning in background in windows phone. They they wont even give a **ahem** now because their team is now focused on new editions of fit bit watches. SO RIP.
05-16-2016 10:40
05-16-2016 10:40
05-18-2016 03:43
05-18-2016 03:43
05-18-2016 09:20
05-18-2016 09:20
TandemWalker you seem to be missing one important thing about all your suggestions, and that is the sync used to work and now it has stopped working reliably and not because of things users have done. It is something that FitBit has changed that is causing the problems.
06-03-2017 12:07
06-03-2017 12:07
Mine hasn't synced since 22/04/17
06-03-2017 17:12
06-03-2017 17:12
I have the same problem, after an app upgrade late last week. Tried all the suggestions in this forum up to and including deleting the app and the Bluetooth pairing then reinstalling. No luck. It is clear that something went wrong in the last app upgrade. I have even tried using my windows pc but same problem.
Come on Fitbit. Fix the problem with the latest app upgrade.
06-05-2017 21:41
06-05-2017 21:41
My One also will not sync to my PC (windows 10- bluetooth paired...uninstalled/reinstalled app...restarted pc etc. Thankfully it syncs to my phone, but I want it to sync to my pc as well. It just started a few days ago acting screwy...showing accurate steps then reverting to previous sync, etc. Now it says tracker disconnected. It has to be the app.
06-07-2017 21:32
06-07-2017 21:32
I just finally got my windows 10 app to sync to my one...Uninstalled the app. Made sure I disconnected my one from my phone...Restarted my PC. Then did a ccleaner and registry repair on my PC. Reinstalled the app. Signed in... and SYNCED!!! YAY!!! I had tried uninstalling/reinstalling before, but hadn't done the ccleaner etc. I think that did the trick. Just happy to get my PC to sync my fitbit. I like that it syncs my fitbit when I walk in the house and saves my phone battery.
06-21-2017 09:22
06-21-2017 09:22
Having sync problems again . Have fixed many times. I think I will give up on fitbit & go to garmin.
06-21-2017 10:29
06-21-2017 10:29
Thanks - will try this!
