had mine only connected to phone until today and then tried the computer and it also will not work.
Best AnswerI am also having the same sync issues. I have tried all the usual tricks - uninstall and reinstall the software on both phone and PC, reset, turn bluetooth off and on, and nothing works. Mine hasn't synced since Friday. It's never done this before, normally if I have a sync issue on my phone it will work on my PC, and vice-versa. So frustrating!
EDITED to add: It now seems to be working again, so I'm not sure what the issue was!
what is the dongle
Hi @dmcglannan.
This is the dongle. It's about the size of quarter and must be plugged into a USB port off a computer in order to sync via the Fitbit app or Fitbit Connect.
TW
Hi @stillmax. I just checked your profile and it looks like you were syncing just fine until Feb 4th. So what happened afterwards? What device are you syncing with - a phone, a computer ... If the latter, can you tell us more about your configuration ... If you have a Charge HR, you may get better and quicker feedback reposting in the Charge HR forum - this forum here is for the Fitbit One.
TW
Hi @stillmax. I replied to your earlier post. Unfortunately, your second post does not contain any more information that would allow anyone here to offer troubleshooting tips. And as mentioned earlier, you would probably get better feedback by posting in the Charge HR forum. This forum is for the Fitbit One. Should you decide to repost your query, the more information you include the better the odds of getting targeted tips. Perhaps the following document will help I can't sync my tracker . Have a nice day.
TW
Best AnswerSame issue
I upgraded the OS because I thought the may be the issue with my phone and nothing./
I have gone out to my car and removed all Bluetooth devices from proximity and nothing. It is fully charged and the iPAD, PC, MacBook, and iPhone will not sync.
Recharged it overnight and nothing. Rebooted machines, replugged in dongle.
WHAT IS GOING ON?
Best AnswerMine is not working for several weeks either on the charge HR...
is someone at Fitbit fixing this?
My clock is not set right so I cannot even use it as watch
I have emailed support but no reply yet
Best AnswerI tried your suggestions, but canot find the sync now button. I am trying to sync my ONE to my computer. Please help. Thanks.
