01-15-2016
05:34
20:15
01-15-2016
05:34
20:15
01-22-2016 09:23
01-22-2016 09:23
Thank you very much for your update @Ktorrez! At this point, please contact Customer Support, they will be more than happy to further investigate what is going wrong with your tracker.
Please let me know how it goes!
If this post was helpful vote for it or accept it as a solution! Remember challenge yourself and become better than yourself. Share your story!
01-16-2016 11:52
01-16-2016 11:52
Hello @Ktorrez, very welcome to the Community! I used to have the same issue every time I was on my spinning class. Try to restart your tracker one more time and after that set up your tracker as a new Fitbit device. That works for me
. Also, just remember that active minutes are only awarded after 10 minutes of continuous moderate-to-intense activity.
Let me know how it goes!
01-18-2016 14:40
01-18-2016 14:40
01-19-2016 11:36
01-19-2016 11:36
Thanks for the update @Ktorrez. I saw that massage on my phone a few weeks ago. So, please try clearing your Fitbit app browser's cache, by logging out of the Fitbit app, after that, go Settings, try to find General usage, tap Manage Storage, tap an item in Documents and Data. Slide unwanted items to the left and tap Delete. Tap Edit and Delete All to remove all the app's data. Finally, log back into your Fitbit app and try to set up your tracker one more time.
Keep me posted, I'll be around!
01-21-2016 19:03
01-21-2016 19:03
01-22-2016 09:23
01-22-2016 09:23
02-10-2016
16:49
12:47
TarinFitbit
02-10-2016
16:49
12:47
TarinFitbit
Mine is doing the same thing.
Moderator edit: all caps
02-11-2016 13:05
02-11-2016 13:05
Nice to see you around @barter! Have you tried a Factory Reset on your tracker?. If you don't, I recommend to do it at first thing in the morning and after that set up your tracker
as a new Fitbit device and test it for one day.
Let me know if the issue persist, I'll be around!
02-11-2016 13:52
02-11-2016 13:52
Thanks for sharing this great tip @Ktorrez! I'm going to share your tips every time someone needs it. At the moment, could you please let us know your updates?
Keep me posted!
02-13-2016 15:27
02-13-2016 15:27
A simple reset solves the problem but it came back a second time. The reset worked the second time too but I hope this doesn't become a regular thing.
02-15-2016 13:26
02-15-2016 13:26
Thanks for joins us @barter! Have you tried to clear the browser cache on your computer?. Directions on how to clear your cache on a variety of browsers can be found here: http://www.wikihow.com/Clear-Your-Browser's-Cache
Please keep us posted on your updates!
02-23-2016 14:52
02-23-2016 14:52
I don't sync to a phone. I sync to my desktop.
02-26-2016 13:31
02-26-2016 13:31
Hello @Coralee thank you for your information! At this point, I recommend to contact Customer Support, they can further investigate this issue and get you back on track.
@barter Thanks for your update. The instructions I placed in my last post are for computer. Have you tried to clean your computer browser cache?. After that, try to sync your Charge HR with your computer and test your tracker for one day.
Let me know how it goes @Coralee and keep me posted @barter!
03-04-2016 11:00
03-04-2016 11:00
I wish I had read these community posts before I purchased this Fitbit HR! I purchased the HR to track activity for a company sponsored Wellness program. My fitbit Charge worked fine, but it keep falling off, so I paid another $150 for the HR with the regular watch strap. My Fitbit HR did not work out, wouldn't tell time or track activity, from the moment I bought it.
Phone support was able to get my ChargeHR to track my activity, but every week it quits working. I won't purchase a third fit bit, but I must warn consumers 'DO NOT BUY A FITBIT CHARGE HR. The company should offer a recall until the company can fix these problems. It is giving Fitbit a bad reputation with large corporationsw
03-05-2016 07:22
03-05-2016 07:22
Hi @workingmomof3 thank you for join us on the Community and also thank you for sharing this information with us. I really understand you, I do like my Charge HR. Have you tried to contact Customer Support again? They can further investigate your issue and I'm sure they will find a quick solution for you. In addition, let me share the Fitbit Warranty Policy.
Keep me posted!
04-05-2016 10:05 - edited 04-05-2016 10:06
I have had the exact same problems with my charge HR syncing as the other individuals on this thread. None of your troubleshooting advice works. Your customer service support team is a joke and extremely unhelpful- once they FINALLY answer you with something other than a generic reply. It seems as though this is a well known issue with your charge HR devices. Fitbit as a brand should take ownership for this common malfunction.
04-05-2016 14:04
04-05-2016 14:04
Thank you very much for your feedback @kwilli49. You are correct, this might be a bug. So, make sure you are running the latest version of the Fitbit app. Fitbit regularly provides new versions of the Fitbit app on the App Store and PlayStore, these updates offer new features and bug fixes. To update your tracker, follow me:
1. On your iOS device, tap App Store.
2. Tap the Updates tab.
3. If a Fitbit update is available, you'll see Fitbit in the list of pending updates and tap Update.
04-05-2016 15:38
04-05-2016 15:38
