01-15-2016
05:34
20:15
01-15-2016
05:34
20:15
05-18-2016 10:15
05-18-2016 10:15
I notice this problem over the last few days. The Active minutes are zero and i did a restart
Best Answer05-18-2016 16:01
05-18-2016 16:01
Hey guys @Tomduffy @kwilli49 thanks for join us!
@Tomduffy there is a New Fitbit app version, I totally recommend to Update your Fitbit App to the Latest Version, that helped me.
@kwilli49 at this point I recommend Contact Costumer Support, they will be more than happy to help you.
I hope you an be back on track soon guys!
If this post was helpful vote for it or accept it as a solution! Remember challenge yourself and become better than yourself. Share your story!
Best Answer09-01-2016 15:47
09-01-2016 15:47
tried this didn't work
Best Answer09-02-2016 00:52
09-02-2016 00:52
Best Answer09-09-2016 11:18
09-09-2016 11:18
I'm having the same issue with the Fitbit One. I had walked for 21 minutes in the morning, then biked for 42 minutes in the evening. When I initially logged it, I had a total of 63 active minutes, but then I found I had entered the incorrect amount of calories burned. Unfortunately, you can't edit the entry, so I had to delete and reenter. When I did that, my total active minutes went back down to 21. I have tried rebooting the app, taking off wifi and Bluetooth, then rebooting Bluetooth and the app. Still will only indicate 21 active minutes. I think there at least needs to be an edit feature added to the exercise portion, like there is on the food.
Best Answer09-09-2016 12:04
09-09-2016 12:04
Best Answer10-09-2016 12:02
10-09-2016 12:02
Best Answer10-09-2016 12:06
10-09-2016 12:06
Best Answer01-29-2017 17:57
01-29-2017 17:57
I am having the same problem mine is not picking up any active minutes for like 4 days now. I looked at it at one poing on Thursday and it said 58 min then i looked a few minutes later and it said zero and has been that way ever since
Best Answer01-29-2017 23:52
01-29-2017 23:52
Best Answer03-24-2017 19:02
03-24-2017 19:02
I'm having the same issue with my charge hr. I have tried everything suggested in this thread, but it's still not logging the active minutes. Today I did 30 mins on my rowing machine and no active minutes were logged. This is the first time this has happened to me and it's messing up my goals that I like to achieve by the end of the day. I'm at a loss and very disappointed. It's too late to call Customer Service, but from a couple of posts, that probably won't help anyway.
If anyone else has any suggestions, I would gladly try them.
Best Answer01-17-2018 22:28
01-17-2018 22:28
Active minutes nit syncing. Huh. Can they be entered manually?
Best Answer01-19-2018 15:53
01-19-2018 15:53
Best Answer01-20-2018 00:42
01-20-2018 00:42
Sometimes unless the exercise is very active it won't register. A
Best Answer01-20-2018 05:44
01-20-2018 05:44
Best Answer03-22-2018 07:53
03-22-2018 07:53
Unfortunately that did not work for me. 😞 Active minutes STILL not syncing.
Best Answer08-25-2019 19:48
08-25-2019 19:48
This post is 3 years old but still solved my problem. Charge 3 still will not sync properly if on wifi. Turned it off and BT took over and synced everything. Stupid app. Not buying another Fitbit. Am done. Thanks Ktorrez.
Best Answer03-04-2020 16:19
03-04-2020 16:19
Have the Alta HR. Friend gave it to me last week. Worked out 60 mins high i density and never synced active minutes. Trouble syncing in General. Reset device multiple times. Loaded as a new device twice and deleted and reinstalled app 3 times. Bit annoyed.
Best Answer08-02-2022 07:19
08-02-2022 07:19
That worked for me! thanks so much -everything else - turning on/off, resetting, factory resetting didn’t work but disconnecting wifi, reconnecting bluetooth worked -
Best Answer03-15-2023 17:08
03-15-2023 17:08
Thank you so much! That trick worked!!👏👏
