08-14-2017
12:02
09:26
08-14-2017
12:02
09:26
When I try to turn in all day sync it tells me I need to pair my tracker wven though it's already paired and when I click set up it just say looking and loses connection with tracker. I then have to force close app and turn off all day sync before it phone can connect with the tracker.
12-06-2018
17:34
11:34
HeydyF
12-06-2018
17:34
11:34
HeydyF
I completely agree
Moderator edit: Removed personal info
Best Answer12-06-2018 23:02
12-06-2018 23:02
04:17
11:35
HeydyF
12-07-2018
04:17
11:35
HeydyF
I have done this twice. I have uninstalled the app and it will connect the charge just not the notifications I have finally given up
Best Answer12-07-2018 09:46
12-07-2018 09:46
Sorry, I misunderstood your original post. The tip I gave (pinched from Mesirm) does seem to work most times in ,making all day synch work but if you are asking about notifications then I have that issue as well as you. My Charge 2 used to send me notifications but stopped and rebooting, deleting and reinstalling have all failed. The settings tells me that notifications are enabled but when I check on the watch itself it says 'notifications off' - if I find a solution I'll let you know.
Best Answer12-07-2018 09:50
12-07-2018 09:50
If it is notifications try this - tap the watch to get the clock face (doesn't matter which clock you use) then press and hold the button and notifications should pop up and reset itself to on - hope that helps.
Best Answer12-17-2018 23:35
12-17-2018 23:35
Thanks this is the only thing that worked I tried all the other ‘fixes’👍😊
Best Answer12-18-2018 05:16
12-18-2018 05:16
Glad to be of help.
Best Answer01-16-2019 10:06
01-16-2019 10:06
i have been having this problem for days. thank you so much!
Best Answer01-16-2019 10:09
01-16-2019 10:09
Best Answer01-30-2019 07:56
01-30-2019 07:56
Thank you so much for posting how you got your Fitbit to all-day sync. I noticed tht you MUST click on Notifications rather than turning on the all-day sync. That was the only way i could get mine to work! I followed all your steps, but when I opened Fitbit again, I tried to turn on all-day sync first and it didn’t work. When I clicked on notifications instead, that worked! 🎉🎉🎉
Best Answer01-30-2019 09:12
01-30-2019 09:12
Glad it worked for you, mine still sometimes drops off if I let the battery get too low and then I'm back using the 'fix'. It's really surprising that Fitbit haven't issued a software update to fix this permanently.
01-30-2019 13:38
01-30-2019 13:38
06-02-2019 09:07
06-02-2019 09:07
Thanks so much for your answer. I’ve been trying to find a solution for days.
06-08-2019 06:12
06-08-2019 06:12
I was having bother syncing my fitbit and came across your answer and i'm pleased to say your answer helped me fix the problem i was having with my fitbit
06-08-2019 06:14
06-08-2019 06:14
Best Answer06-08-2019 07:18
06-08-2019 07:18
These companies don't care. Once you buy their products, they go ghost.
06-09-2019 05:24
06-09-2019 05:24
Best Answer07-20-2019 07:51
07-20-2019 07:51
Thank you, it works now!!!
Best Answer08-11-2019 07:40
08-11-2019 07:40
Thank you this worked for me - I was beginning to give up!
Best Answer08-11-2019 12:26
08-11-2019 12:26
