01-07-2016
00:11
20:42
01-07-2016
00:11
20:42
01-08-2016 04:42
01-08-2016 04:42
Welcome to the Fitbit Community @mark_wood! It's great to have you here!
Allow me to help,in this case the first step to do is the restart if it doesn't work you can also try changing your clock display.
Hope it helps, let me know how it goes!
01-08-2016 05:33
01-08-2016 05:33
Same problem, black bar, half white/half black, tried restarting, updating, etc. will not work. Also, when trying to sync, an exclamation point icon pops up in the middle of the bar. Any suggestions?
01-08-2016 05:46
01-08-2016 05:46
Hi @mpmaster and @mark_wood , that is usually an indication that your Fitbit is stuck in the middle of an update. If you are trying to update using your phone or tablet, please try updating using your computer, if possible. That is often more straightforward. More information here: https://help.fitbit.com/articles/en_US/Help_article/How-do-I-update-my-tracker
01-12-2016
11:34
07:34
01-12-2016
11:34
07:34
02-15-2016 16:19
02-15-2016 16:19
Hi Mark,
I am having this exact same issue - was wondering what you did to fix it.
04:34
07:34
02-16-2016
04:34
07:34
It's great to see that you've visited the Fitbit Community @kturner_14!
Let me help you out, by any chance have you tried the suggestions posted above? If you've tried it and the issue persists I recommend you contacting Support so they can review your device history and check your options.
Keep me posted!
02-16-2016 09:02
02-16-2016 09:02
It was a problem with my phone and not the fitbit. I just had to restart my phone and allow it to finish the update then it worked.
04:38
07:35
02-17-2016
04:38
07:35
@kturner_14 It's great to hear that you're back on track :D.
Hope to see you around more often!
06-23-2016 06:36
06-23-2016 06:36
I too am getting the half white/half black bar on the screen of my HR. It will not turn on or do anything.
Where should I start?
07:25
07:35
06-23-2016
07:25
07:35
Hey there @snewe66! Welcome aboard! Start doing the restart 2 or 3 times in a row find the instructions below.
1. Plug your charging cable into the USB port and insert the other end into the port on the back of your Charge HR. Your tracker will begin charging.
2. Press and hold the button for 10 to 12 seconds until you see the Fitbit icon and a version number (e.g. "V88").
3. Let go of the button.
4. Unplug your tracker from the charging cable.
Your Charge HR is now restarted and should work normally, keep me posted
Best Answer06-23-2016 17:42
06-23-2016 17:42
05:49
07:35
06-24-2016
05:49
07:35
@snewe66 It's a shame to hear that you still experiencing this issue, if you have already tried the restart several times and the issue persists, I highly recommend contacting support the Support Team so they can review your device history and tell you the options.
Let me know the outcome!
Best Answer03-05-2017 23:25
03-05-2017 23:25
I'm in the exact same situation as Karen. I tried the restart multiple times, and it did nothing. Still just half-filled bar. This is frustrating. What is the problem/solution?
11:48
07:35
03-09-2017
11:48
07:35
Hi there @Traceyml!
Let me help you with your tracker. Try removing your tracker and then set it up as a new device. To remove your tracker follow the instructions below:
Let me know how it goes!
03-28-2017 20:27
03-28-2017 20:27
I have the same problem and tried the same steps but the problem still persists
Best Answer08-08-2017 16:39
08-08-2017 16:39
Hi, I have the same problem on my fitbit HR. Block line half white. I have tried the plug in to charge, hold button to reset, and unplug multiple times. I restarted my phone to see if the syncing or downloading was the problem and no luck. Any other suggestions? Or is my precious fitbit a goner?! I hope not.
Best Answer08-09-2017 17:28
08-09-2017 17:28
I am having the exact same issue. I have tried to restart several times and nothing happens. I've also uninstalled and reinstalled and the line remains. Has anyone actually been able to get past this issue? I have also checked for updates on my computer and it says each time it is up to date.
Best Answer08-10-2017 05:05
08-10-2017 05:05
Its a goner. If your fitbit is still under warranty you can call the customer care and get a replacement. If not call them anyways and explain to them the issue you have. They will give you a discount on a new one (this is what i got)
Best Answer08-10-2017 05:06
08-10-2017 05:06
