06-28-2018
19:30
18:22
06-28-2018
19:30
18:22
Has anyone had a problem with Charge 2 burning their wrist? This happened with my first Charge but I thought the problem had been solved.
06-29-2018 06:25
06-29-2018 06:25
Hi, I have had the same issue since last week, I thought I had splashed something on the strap ( which is fine) but I have a nasty burn on my wrist under where the strap was. And have had to stop wearing my fit bit for the first time in 2 years to give my arm time to heal.
Best Answer06-29-2018 07:46
06-29-2018 07:46
Best Answer06-22-2019 06:22
06-22-2019 06:22
It's the lights the two green lights and the square panel. I thought it was a rash but after getting it looked at my skin was actually burned. When you start to notice hot tingling feeling need to take of . It will take off your hair and leave a fitbit tattoo
Best Answer06-22-2019 19:47
06-22-2019 19:47
