09-26-2018
22:29
18:22
09-26-2018
22:29
18:22
When I went to log my weight, I noticed that the date was wrong for Sept. When I investigated a bit more I found that September has eight days showing for the week instead of seven. I then checked August and found that August and October also show eight days during the week instead of seven. Needless to say, that also messes up the day of the week. Anyone else have this problem?
09-27-2018 04:46
09-27-2018 04:46
@ZXY A warm welcome to our Community! Sorry to hear that calendar is showing incorrectly on your account. Could you share a screenshot of these dates? Also what are you using to view your data (phone or computer)?
I look forward to your reply!
09-29-2018 10:58
09-29-2018 10:58
Sorry for the delay in response. Unfortunately I am unable to get a screenshot of the calendar, I've tried a number of things with no success. I have looked at the calendar a number of times and it has not been correct since I first noticed it on the 27th. So far I have seen it with eight days showing for each week and six days showing for each week. I haven't see seven days showing for a week at all. Today it shows six days for the week. The date i.e. Sept 29th is correct but the calendar shows the 29th being on a Friday instead of Sat. I am using my computer to look at the calendar and have had no problems prior to the Charge 2. I am also using Windows Explorer V11 as my browser.
I also took a few minutes to peruse the plethora of complaints regarding the Charge 2 that have come in within the last two days. It looks as if the Charge 2 is having all kinds of problems that others are dealing with aside from my calendar issues. What is going on with the Charge 2? I have had it for less than a week but with all the issues I'm seeing posted, it makes me question the advisability of getting the Charge 2. With the number of issues I'm seeing, it appears that Fitbit has a bit of work to do to ensure that the Charge 2 works as it should, so far, I'm not sure it does.
Any suggestions regarding the calendar would be appreciated. I'll also keep trying to get a screenshot and if I can I'll sent it to you.
XYZ
09-25-2019 06:00
09-25-2019 06:00
I have the incorrect date on mine as well. Is there a solution for this? Mine states it is about a month ahead.
09-25-2019 12:01
09-25-2019 12:01
I'm sorry I don't have an answer for you. I never did receive a satisfactory answer for any kind of fix for my calendar problem.
However, somehow, I'm not sure what happened, or when it happened, but my calendar is now correct and has been for the last little while. I don't what changed to get the calendar corrected but I now show a correct calendar.
Good luck with yours, hopefully it will spontaneously correct as mine seems to have done.
ZXY
