10-04-2018 09:52 - last edited on 11-17-2020 15:47 by MatthewFitbit
I have a Charge 2 that I love and have it synced with my computer which I prefer to having it synced to my cell phone. Will I be able to do that with a Charge 3?
Moderator Edit: Updated Subject for Clarity
10-04-2018 10:33
10-04-2018 10:33
If your Charge 2 works well with your computer, the Charge 3 should also.
Helen | Western Australia
10-04-2018 10:33
10-04-2018 10:33
10-04-2018 12:32
10-04-2018 12:32
Charge 3 shows up on Fitbit Connect, so it should have no issues!
MakMak | Community Council
10-04-2018 15:22 - edited 10-04-2018 15:23
Thanks Nelly and MakMak!
10-07-2018 06:27
10-07-2018 06:27
@Levi2646 Welcome to the Fitbit family! Thanks for taking the time to post on this thread regarding your Charge 3 syncing to a computer. I'm really glad that you found some valuable help here.
I just wanted to jump in here to ask you how is your experience so far while syncing to a computer? Is it syncing properly as your previous tracker?
@MakMak @NellyG Thanks for sharing your awesome help and experience on this thread!
Keep me posted!
10-07-2018 11:08 - edited 10-07-2018 12:23
NellyG I was hoping you were right, but I don't think it works!
When trying sync my new Charge 3 with Fitbit Connect (windows 10) the Charge 3 is not listed. I don't always have my phone around, and many times I turn off Bluetooth. Seems another oversight on this new model.
I have updated the FitBit Connect software and it still gives me no option to connect to my Charge 3.
If anyone has any insight to this problem I would welcome it!!
EDIT: I got it to work with the Bluetooth Dongle!! You have to Uninstall all versions (even the newest version) of the FitBit Connect software. Then go to the Windows store and download the FitBit app. Start the app and connect the dongle. (USB 2 only btw) It finally found it and sync'd. woot
10-08-2018 06:59 - edited 10-08-2018 07:03
SandiFitbit, I was asking before buying the Charge 3 because that was important to me to be able to cynic to my computer, not a cell. But I just found out the Charge 3 doesn't have a face that shows the date and time which is a total deal breaker for me. So I'll stick with my Charge 2 for now.
10-10-2018 10:08
10-10-2018 10:08
Does anyone know whether the Charge 3 requires the Fitbit Bluetooth dongle (eg, https://www.fitbit.com/shop/accessories/wireless-sync-dongle ), or whether it will sync with Windows 10 using any Bluetooth dongle?
10-12-2018 11:04
10-12-2018 11:04
The Charge 3 did not work with my Acer laptop/tablet and the Charge 2 works fine.
Worked on troubleshooting this for over 4 hours. I did get the C3 to work with a dongle (Fitbit)
but if I want to change the clock face I must turn on Bluetooth and the pair/ connection fails.
Tried to work this on issue 2 different Charge 3s.
Went backed to my Charge 2. This is what I did via this Community thread:
10-15-2018 08:09
10-15-2018 08:09
The Charge 3 only syncs and can only be setup using a phone or PC with window's 10. Plenty of us PC users don't want to switch to window's 10. Fitbit connect also does not work with it. Previous charge models as well as the alta models and blaze can connect to windows 7 or 8 and use fitbit connect. Please update this. Thanks.
11-11-2018 09:59
11-11-2018 09:59
After setting up my Charge 3 with an Ipad, I am able to sync using Windows 7. However, I think it will only sync manually. I did download the latest fitbit connect software, but it does work. I have more settings available on the Ipad, but I just wanted to be able to sync on my desktop. Fitbit really should support Windows 7 since there are a lot of them out there and still supported by MS.
12-18-2018 09:09
12-18-2018 09:09
I can't get the charge 3 to do an update. It is new today and was found by the app and recognised on fitbit.com but won't connect via Bluetooth in order to sync and do an update. I've followed the help pages and removed and reinstalled the Fitbit app, removed the old charge 2 from the Bluetooth group and from the dashboard. And still nothing. It tells me it can't be used until the update is complete. Not happy!
01-22-2019 16:45
01-22-2019 16:45
I just turned on the Bluetooth that is built into my laptop. No dongle at all. My Charge 3 syncs beautifully with my laptop (but has stopped syncing with my phone - still working on that issue).
01-22-2019 16:48
01-22-2019 16:48
I think you must be thinking of a different device. My Charge 3 has several options for clock face including date, time, steps etc. I just switched mine to an analog clock face with the date above it and my step count below.
01-22-2019 16:53
01-22-2019 16:53
I tried before, and syncing a Charge 3 doesn't work on a computer, it only works on an mobile device
01-22-2019 17:07
01-22-2019 17:07
From a long time ago..I have tried 3 different Charge 3 on 5 different and current Windows 10 laptops with the current Bluetooth drivers and the Bluetooth fails to connect. I can use a dongle but anything that needs a Bluetooth connection like clockface or current heartbeat does not work. I am back to my Charge 2. The Charge 3 is designed for mobile devices not most current PC/Laptops.
Here is another thread on this:
01-31-2019 17:14
01-31-2019 17:14
hi I think this was a deal breaker for many people, so they have added other faces with date and time now.
05-13-2019 16:52
05-13-2019 16:52
My Fitbit Charge3 will NOT link with a Toshiba with bluetooth enabled, even when connected via the charging cable but will with my phone. I do NOTwant to sync via phone, only via WIndows 10. My wife's Alta easily syncs to her computer whether connected via charging cable or not. Has Fitbit stupidly not built this "direct to Windows 10 computer capacity" into the charge3?
07-18-2019 20:01
07-18-2019 20:01
Is there a solution for syncing a Charge 3 to a laptop instead of a cell phone?
I had purchased an InspireHR and it synced once during set-up and would not sync again - no matter how many times I removed and tried again, downloaded software, etc. I sent it back after finding many people had similar problems.
A week ago I decided to try again with the Charge 3 -- and it set-up and worked beautifully -- the first time! When I got home tonight and tried to sync, it failed and now it will not attach again to Bluetooth and sync.
I have a new Win10 Dell and other items including mouse have synced perfectly. But I cannot get the Fitbit devices to sync again after the initial set-up.
If it were a problem with my computer or Bluetooth, why would it sync so perfectly the first time during set-up and never again?
What do I need to do? Or is it the Fitbit devices which do not sync properly with a computer? I also do NOT want to sync to a phone.
HELP!!!
12-02-2019 13:54
12-02-2019 13:54
It does have a face that shows the date and time so you might want to upgrade after all 😊
