08-03-2017
07:07
09:26
08-03-2017
07:07
09:26
Can i get a new blue tooth code from any were as I have lost mine. I tried to reset my tracker only to find I need the blue tooth 4 digit code to do so. And i am now unable to sync Tracker to my phone (HELP)
Hey my friend @LordHorn, hope you're doing great! I'm a bit confused let me say... are you trying to find the 4 digit code when pairing your tracker? If so, the digits are located on your tracker. What means that when setting it up you'll ask for this numbers at what you need to take a look at the Charge 2 screen as they'll be prompted there.
If you keep having issues with the setup, I'd recommend doing what I posted here. If the inconvenience is not setup but syncing, syncing difficulty is usually caused by a missing requirement. Let's verifying this:
Depending your Android device, these tips might make syncing easier:
If your tracker still won't sync properly, try these steps:
Hope this helps, keep me in the loop!
Music to my ears @LordHorn! So happy to hear you could set up your buddy. Is everything running smoothly now? ![]()
Hope to see you participating in the Community more often since I think it would be awesome for you to explore our Community. You can go ahead and log to any of the topics that might be of your interest in our Discussion boards. Feel free to comment and contribute with your knowledge and experience.
Happy stepping my friend!
Best AnswerThank you sooo much !! I went thru 6 hours searching and trying different things to get this to work. Your answer was the one that worked. I don't know if it was the turning off 3 times that did it or what but I got my 4 digit code and everything is setting up. Many many thanks!
I have tired everything and when I try to sync it, my phone is asking for the code but the Fitbit charge 3 isn't showing me a code to enter. It did at first, but it wouldn't sync after and now I'm not getting anything.
Hello, @MarreFitbit. I tried your suggestions without resolve. I bought a used Versa 3 and am running into a similar issue. When my iPhone and Versa 3 successfully connect via Bluetooth I’m prompted to enter a 4 digit code on both my iPhone,through the Fitbit app, and by my Versa 3. At no point have I been given a pre assigned 4 digit code by my Versa 3 or iPhone. I’ve tried entering a 4 digit code of my choosing on both without success. Advice?
Best,
12:10
06:10
02-11-2023
12:10
06:10
Hello @akellerr and welcome to the Community. Can you please clarify a few things? Where is this code request happening in the + Set Up a Device sequence? When you set up a new device, you select + Set Up a Device, then select Versa 3. The Bluetooth pairing code appears on the Versa 3, you enter it in the Fitbit app and continue the rest of the set up. If your Versa 3 is asking for a code, then it sounds like the previous owner had a device lock with a PIN code and didn't clear the user data before selling it.
Do you know the previous owner? If the Versa 3 is asking for a PIN code, the previous owner might be able to help you. Does this make sense?
You will definitely need help from Support if the previous owner set a device lock and you can't contact them.
Laurie | Maryland
