02-09-2018
12:02
18:54
02-09-2018
12:02
18:54
Charge 2 screen went black. The green lights on still. I tried charging, restarting but no luck. It vibrates and shows working on app. Any ideas???
10-05-2020 08:08
10-05-2020 08:08
Just been on live chat with fitbit. Mine is out of warranty so they've offered 35% discount off a new model (except sense and versa 3 etc)
10-06-2020 14:50
10-06-2020 14:50
10-06-2020 20:44
10-06-2020 20:44
Tks for tip. Old charge 2 died yday, RIP.
ordered with 35pct rebate the Versa 2 spec ed. Seemed a good buy.
10-09-2020 06:57
10-09-2020 06:57
Mine did the same and i used the discount that i got but the fact that this fault has been around for over 2 years is a bit shocking and something they should have fixed i was sent my charge 2 as a replacement for a faulty charge 1 as a free replacement but was not aware of this issue was strange that they supplied a item that had a known fault
10-09-2020 07:23
10-09-2020 07:23
10-09-2020 16:43
10-09-2020 16:43
Same issue, the screen started to be off center for a few days, then upside down for a few. Kept resetting and then eventually went dark. it still syncs with the app but the HR monitor doesn't seem to work. I know its working but without the screen its not that helpful. I have only had for maybe 2 years so it seems like it should last longer.
10-09-2020 21:57 - last edited on 03-05-2021 19:00 by LiliyaFitbit
Mine is older, but now it is dead. The 2nd green light went out the other day but a new Fitbit is on its way, tks to the 35% rebate. So I am ok now.
Best regards
Sent from my iPad
10-09-2020 23:52
10-09-2020 23:52
10-11-2020 06:17
10-11-2020 06:17
10-11-2020 06:25
10-11-2020 06:25
10-20-2020 14:16
10-20-2020 14:16
Hi sorry to ask...I have the same issue...had my charge 2 for 2 years tried everything listed in all these messages and my screen is blank...it will not show any info. How can I resolve this or is this then end of its life and now need to buy a new one...thanks
10-20-2020 15:59
10-20-2020 15:59
My screen is doing the same thing. It will sync to the app and he’s counting my steps will also vibrate when I get a text notification on my phone but I don’t see anything on my screen. I’ve tried the charger and holding the button on the side down for 10 seconds and I’ve tried everything mentioned above. Nothing seems to work.
10-20-2020 19:22
10-20-2020 19:22
10-20-2020 19:35
10-20-2020 19:35
10-20-2020 20:05
10-20-2020 20:05
10-20-2020 20:45
10-20-2020 20:45
10-20-2020 21:23
10-20-2020 21:23
10-20-2020 23:39 - edited 10-20-2020 23:40
Same problem and the process to correct it has not worked for me! Another "gadget" that is not meant to last - so sad this throw-away society is that we live in!
10-20-2020 23:41
10-20-2020 23:41
Why is everything we buy these days not meant to last?
10-21-2020 07:38
10-21-2020 07:38
