02-09-2018
12:02
18:54
02-09-2018
12:02
18:54
Charge 2 screen went black. The green lights on still. I tried charging, restarting but no luck. It vibrates and shows working on app. Any ideas???
09-13-2020 14:39
09-13-2020 14:39
I have tried all suggested. Only get a blank screen with horizontal lines. I have only had this fit bit for 6 months.
09-13-2020 21:18
09-13-2020 21:18
I have done everything and still no luck . What happens now?
09-14-2020 00:25
09-14-2020 00:25
Please can you let me know who I can complain to about this I love my fit bit however it’s seems that this is happening to people all the time and you are not addressing it. I have tried everything and I need to know what I can do. I hope they do not only have a life of 18 to 24 months. Please help
09-14-2020 10:15
09-14-2020 10:15
09-15-2020 23:36
09-15-2020 23:36
Mine has done this as well. Yesterday the screen reversed itself I managed to correct that and now the screen has died the lights are on and it vibrates but the screen is black.
09-16-2020 16:54
09-16-2020 16:54
Mine too. The screen was patchy and glitchy for a while and now nothing. I'm not impressed. My first Charge was replaced as it literally fell apart, they sent me an Alta which was ok. Then this charge hasn't lasted long. I'm not sure if i should stay with the brand or not.
09-17-2020 16:56
09-17-2020 16:56
I have the same problem and so far nothing has worked to get it started. A couple of times stripes of light flashed briefly on then off quickly but that is all the life there is except green flashing light on the back and vibrating.
10-01-2020 07:18
10-01-2020 07:18
February 2018 FitBit responds to the first one or two customers with rote reset instructions and asking if USB is faulty or points are dirty... yet you acknowledged it was charged. Dozens of customers complain of the same... and nothing but silence from FitBit. September 2020... My Charge 2 has the same problem now. I would buy a new VERSA 3, $75 more than my original Charge 2 price, but I am tired of FitBit quality issues. How can I justify spending $220 on a disposable wearable?
10-01-2020 08:08
10-01-2020 08:08
no i wouldn't buy another fitbit. They are expensive and go wrong just after 2 yrs so out of warantee. Try a different make....... garmin?
10-01-2020 08:52
10-01-2020 08:52
10-01-2020 09:49
10-01-2020 09:49
Just a quick point. My charge 2 is almost 4 years old. The battery is just starting to show signs of no longer fully charging. But I haven't installed the last update on the charge itself and my phone hasn't had app updates for some time as it is Android 5. Isn't it strange that mine still works?
10-02-2020 08:50
10-02-2020 08:50
10-02-2020 09:49
10-02-2020 09:49
10-02-2020 09:54
10-02-2020 09:54
Mine still works, I just can't see the screen. It will charge and vibrate, and track movement, but I can't see the display to start, stop, or change lotions. Useless. They did offer me a solution, a coupon for a minimal percentage on the new more expensive unit. Given the number of people with the exact same issue in this string, I am not inclined to waste my money. If they were to send me a replacement, I would wear it and give it a fair review, as long as it kept working.
10-02-2020 16:02
10-02-2020 16:02
Should I fee any better since they offered me 30% off??? This is outrageous, they just confirmed this is not worth to repurchase. Unfortunately, I’ll look into another tracker, maybe an Iwatch...
10-02-2020 20:08
10-02-2020 20:08
10-03-2020 07:45
10-03-2020 07:45
100% right
10-03-2020 15:30
10-03-2020 15:30
Me too 2/10/20
10-03-2020 15:32
10-03-2020 15:32
Tried all this still black. Mine is only a little over 2 years old why is this happening.
10-05-2020 00:25
10-05-2020 00:25
My C 2 screen went black two days ago. Lower green led not blinking but sll activities register as normal on iPhone and device charges. Chatted with Fitbit and they promised to come back on warranty issue. Lets see what they say.
