05-26-2019
20:39
15:47
05-26-2019
20:39
15:47
My Chrage 2 fitbit battery is draining withing hrs. I observed that all of sudden that green light at the back of the Charge 2 is too shiney than before. Also on Charge 2 screen i observed bit of water drops. Please help in resolution. I bought Charge 2, 2 years back.
05-27-2019
12:11
07:46
05-27-2019
12:11
07:46
@SumeetRathod It's great to see that you've visited the Fitbit Community!
Let me help you with you Charge 2 battery issues. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
Let me know how it goes.
Best Answer06-01-2019 05:18
06-01-2019 05:18
Thanks for your response. I tried it but still my battery draining within 4 hrs after full charge. One thing which I observed is, now only 1 green light at the back of the FitBit is on and other green light is not on. Now it is not charging at all.
Best Answer06-02-2019 11:32
06-02-2019 11:32
My Charge 2 isn't quite as bad as this one, but it's also dying with no warning after two days. It seems to be charging OK and works fine but then two days later it's dead with no warning (I used to get an email notice when it synced and noticed the battery was low). Suggestions? I can try turning off notifications from my phone although I don't seem to be getting the at the moment, anyway (maybe a related problem?)
