11-09-2016
11:59
10:26
11-09-2016
11:59
10:26
I am unable to toggle between the available menus (Heart Rate, Exercise, Relax, Stopwatch, Alarms). Nothing happens when I press the button. However, I am able to tap the display to see steps, stairs, heartrate, etc. I've tried the resetting it (plugging in and holding the button for 4 seconds until the display shows), but it didn't change anything. Anyone have any suggestions for how I might access the other menus?
11-10-2016 16:42
11-10-2016 16:42
11-14-2016 10:15 - edited 11-14-2016 10:46
Your response may have provided THE KEY. In the PC version, I have everything checked, but it didn't make a difference. However, when I went to the Android App (Devices - Charge 2 - Menu Items), it was not checked there. I just checked those boxes and I'm waiting to see if that works. Keep your fingers crossed!
11-09-2016 13:25
11-09-2016 13:25
I just got my Charge 2 yesterday and I am having the same exact issue with mine. 😞
11-10-2016 07:27 - edited 11-10-2016 07:29
Welcome to the forums @trodier and @Latteloco, it’s great to see you in the Community!
If you haven't done so alreayd, make sure you've tried to perform the restart procedure you mentioned on your device at least three times, this has helped other users who have experienced similar issues. As an alternative, you can also try to setup your tracker as a new device, don’t forget to select “Existing account” during the process.
I hope this helps, keep me posted. ![]()
Best Answer11-10-2016 15:29
11-10-2016 15:29
Best Answer11-10-2016 16:42
11-10-2016 16:42
11-10-2016 18:25 - edited 11-10-2016 18:26
I got mine today and am having the exact issue as well. I have tried all things listed here and none of them have worked. The only way I can go thru the menu is to tap. The button only brings up the hr and exercise. Help!!
Best Answer11-11-2016 01:19
11-11-2016 01:19
Best Answer11-11-2016 04:52
11-11-2016 04:52
Welcome to the Fitbit Community @KKNinn, it’s great to see you around!
If you’ve already tried all of the steps mentioned in my previous post and the steps @designbod provided as well to try to resolve this, I do recommend that you contact the Customer Support team for further assistance with this, and they will let you know how to proceed.
I hope this helps. ![]()
Best Answer11-11-2016 04:54
11-11-2016 04:54
Welcome here my friends @designbod @trodier @KKNinn @Latteloco! If you guys have tried what @DavideFitbit suggested, I'd recommend doing what @designbod did by contacting customer support.
They'll do a deeper investigation and see where the issue is coming from. Don't forget to mention the steps you've done so far to avoid getting the same ones.
Have a great day guys!
Best Answer11-12-2016 08:02
11-12-2016 08:02
Best Answer11-14-2016 09:56
11-14-2016 09:56
Doesn't work...nothing works!
Best Answer11-14-2016 10:09
11-14-2016 10:09
All items "on" and it still doesn't work.
11-14-2016 10:45
11-14-2016 10:45
It works...thank you so much for providing the key!
Best Answer11-14-2016 21:44
11-14-2016 21:44
Best Answer11-15-2016 06:30
11-15-2016 06:30
Have you also tried to select the options on your PC Dashboard @KKNinn? If after tried that, the issue persists, I would suggest you to contact Fitbit Support again, explain them what you have done so far. They will take a look into your account and choose an option to get you back on track.
Let me know the outcome!
Best Answer11-15-2016 07:05
11-15-2016 10:40
11-15-2016 10:40
Best Answer11-17-2016 12:40
11-17-2016 12:40
@Latteloco Are you still having trouble with your Charge 2? If so, I would recommend that you:
1. Open the Fitbit App and click the "Account" button.
3. Click the Charge 2 tile.
4. Click "Customize Display".
5. Make sure that the stats that you want displayed on your tracker are checked and sync your Charge 2 for the changes to take effect.
@KKNinn Did you sync your tracker afterwards? If you modify any of your tracker's settings, you should sync your tracker afterwards so the changes implemented.
Restarting your tracker should also help too. Keep me posted!
Best Answer01-22-2017 10:46
01-22-2017 10:46
I had this problem. Nothing worked. I rebooted my Charge 2 several times in accordance with the Fitbit advised procedure. No joy. I filled in a webform enquiry to Fitbit but I am still awaiting a reply. I finally tried deleting the device from my account and then putting it back. To my amazement the Menu button worked. I will now try to change the menu items
