04-21-2019
12:15
16:26
04-21-2019
12:15
16:26
The screen on my fitbit has cracked all the way down the front (this happened last July when we had the extremely hot weathet) but I've only just got myself into gear to get it reported). How do I go about getting this replaced please? It was only about 3 days past 1 year old when this happened. Thank you
04-22-2019
11:14
09:13
04-22-2019
11:14
09:13
@donnahawk Welcome to the Fitbit Community! It's great to have you here!
I will gladly assist you with your damaged Charge 2 screen. As @SteveH mentioned the best thing is to let our support team know so they can review the issue and provide options. I noticed that you already have a ticket with them so I wanted to know if they were able to help you?
I look forward to your reply.
00:09
10:59
AlvaroFitbit
04-22-2019
00:09
10:59
AlvaroFitbit
This may be a problem.
The warranty runs for 12 months from purchase (or 24 months if you are in Europe) so you will not be covered in you are not in Europe.
Furthermore, the warranty terms exclude accidental damage so you may have a problem persuading fitbit that the crack is the result of a defect.
Your best bet would be to contact customer support and see if they can help in any way: contact.fitbit.com
04-22-2019
11:14
09:13
04-22-2019
11:14
09:13
Best Answer05-20-2019 09:22
05-20-2019 09:22
If you go onto the Chat help line that seems to work the best. My screen has cracked twice and the entire unit replaced twice. I think the Charge 2 screen is faulty. Decided to upgrade to Charge 3 as it has a different charger. Annoyed that I was charged also 10p for added security when using my credit card, my card issuer says FitBit are charging this.
