12-09-2018
10:41
18:22
12-09-2018
10:41
18:22
My Charge 2 has stopped syncing since 12/6. Not sure what’s going on. Can someone help?
12-09-2018 10:52
12-09-2018 10:52
Same here! Since Oct. What can i do??
Best Answer12-09-2018 18:26
12-09-2018 18:26
Same here. Tried all DIY troubleshooting steps, checked the Android version, restarted the device, all following the Fitbit website instructions. No effect. No error messages, - just nothing happens. What else can I try?
Best Answer12-09-2018 19:04
12-09-2018 19:04
Same hear. Googled and nothing helped. Hmmm.
Best Answer12-09-2018 19:22
12-09-2018 19:22
Mine stopped syncing too is there an update?
Best Answer12-09-2018 20:03
12-09-2018 20:03
Mine is also not syncing since Wednesday.
Best Answer12-10-2018 00:56 - edited 12-10-2018 14:14
Hi - My Charge 2 has also stopped syncing with iphone X running 12.1. It first failed 6th Dec . The iphone doesn't recognise the bluetooth connection . I managed to resync by attaching the charging cable to Fitbit and holding the button down until firmware level appears (22.55.02 ). But today (10th Dec ) that fix doesn't work. I have deleted the bluetooth connection from the iphone and attempted to re-pair. The iphone doesn't see the Fitbit at all.
Something must have changed - my Fitbit has worked perfectly for 18 months until now .
Correction - Iphone X running 12.1 not 12.1.1 . Just tried my old iphone 6 on 12.1 - it works ! .
Update 1 - upgrading iphone x to 12.1.1 makes no difference - iphone X still cannot see Fitbit.
Update 2 - escalated to Customer service . They suggested the usual - make sure Bluetooth enabled on only one phone , switch on and off , Bluetooth on and off , restart Fitbit ( as if recharging via power cable and hold button down to firmware display ). This time it worked - but I've tried this before and it fell over again after a day or so . I suggested they took a look at the Community posts !
Best Answer12-10-2018 01:01
12-10-2018 01:01
I’m having the exact same issue. My iPhone won’t recognize it at all. Very frustrating but glad I’m not going crazy. Sounds like an issue on their end. Hopefully they will fix it soon. Also says mine was last synced on 12/5
Best Answer12-10-2018 13:40
12-10-2018 13:40
Same here. It synced fine with my Samsung Galaxy J3 for 4 months since purchase then suddenly stopped on 21 Nov.
Best Answer12-10-2018 14:01
12-10-2018 14:01
The same with my Charger 2 and Samsung Note 3. There has been no syncing since December 7th. I tried the restart function as recommended on a previous post below, but that didn't work. I'm about ready to reset the whole Charger 2, but will wait to see if Fit bit will chime in. They can't be silent too long with all these posts.
Best Answer12-10-2018 14:23
12-10-2018 14:23
Same here. Mine hasn’t synced since 12/3. I’ve tried all of the suggestions and nothing works. Very frustrating!
Best Answer12-10-2018 14:37
12-10-2018 14:37
Just tried something that worked for syncing Charger 2 and Samsung Note 3. Plug in your Fitbit like you are charging it. Then hold down the button on the side of the fitbit for 4 seconds or so until the fitbit logo appears on the fit it screen. This restarts it. At the same time, go to the cell phone fitbit app, under the settings tab and manually sync your device. Hope this works for you.
12-10-2018 17:30
12-10-2018 17:30
Duke 42 thanks. I had tried what u mentioned in days passed but decided to try again. Did it 3 times throughout the day. Sure enough it finally started syncing. Guess it needed to be done several times. Ha. Happy day all.
Best Answer12-10-2018 17:44
12-10-2018 17:44
I'm having same problem since 12/9. I've tried everything
Best Answer12-10-2018 18:10
12-10-2018 18:10
Best Answer12-10-2018 18:16
12-10-2018 18:16
Best Answer12-10-2018 18:47
12-10-2018 18:47
Best Answer12-10-2018 19:03
12-10-2018 19:03
Best Answer12-10-2018 19:04
12-10-2018 19:04
Best Answer12-11-2018 07:23
12-11-2018 07:23
