10-01-2019
00:33
12:16
10-01-2019
00:33
12:16
I am seeing a lot of posts about the issues that I am experiencing with my Fitbit but I am not seeing any helpful responses from anyone at Fitbit. Is there any update as to why my watch is basically worthless?
Literally any information that is not restart or clean contacts would be appreciated.
Could you let us know what issues you are having?
Note that these forums are for users to help each other and they are not monitored by fitbit customer support. So, if you don't get an answer here you will need to contact customer support yourself via contact.fitbit.com
10-01-2019
03:39
12:18
AlvaroFitbit
10-01-2019
03:39
12:18
AlvaroFitbit
It wouldn't charge for about a week and for the past 2 weeks, it dies 10
minutes after I take it off the charger.
03:43
12:18
AlvaroFitbit
10-01-2019
03:43
12:18
AlvaroFitbit
It sounds like you have previously seen the suggestions from fitbit in this help file: https://help.fitbit.com/articles/en_US/Help_article/1190/
Unfortunately, those suggestions, including cleaning the contacts, are for when a fitbit fails to charge. Failing to hold a charge is a different issue and, if a restart is not helping, suggests a defective battery that you're not going to be able to fix.
I would contact customer support. They can check your warranty status and advise on your options.
12:20
07:15
10-02-2019
12:20
07:15
@Khrazie Welcome! Thanks for being part of our Community!
Let me help you with your Charge 2 not charging and thank you for troubleshooting this issue. If you already tried the suggestions @SteveH mentioned then the best thing to do is letting our Support team know about this. I have created a ticket so our Support team can further assist you via email.
Let me know how it goes.
Best AnswerHaving same problem here. Shows it’s charged completely and within a few minutes it’s gone!
Best AnswerThey have contacted me and suggested I do a battery test. I am hoping it'll give me some answers as to what is happening. Thank you for the help, the whole situation has been a bit frustrating,
Best AnswerThat is how mine started and I thought I wasn't paying attention to what I was doing. It got so bad that I put it down for about 2 weeks. I just started using it again and its better but its not where it used to be... it makes it through my shift, which isnt saying much.
I stick with my previous post in this thread - contact customer support
