12-25-2019 06:39 - last edited on 09-08-2020 11:28 by
Fitbit Charger 2 has to be charged every day and a half. Now it’s not charging at all. On app it shows full but screen is blank in a couple of hours.
12-26-2019
08:05
08:26
12-26-2019
08:05
08:26
@Messina Welcome to the Fitbit Community! It's great to have you here!
Let me help you with your Charge 2 not charging. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help your tracker charge.
Let me know how it goes.
