03-06-2020
05:50
10:14
03-06-2020
05:50
10:14
Fitbit was working fine, was at low battery, not even dead, so I put it on to charge. Went to grab it 8 hours later and nothing. No charge. Dead. Is it the charger? The Fitbit itself? Not sure what to do to figure it out, never had problems with it. It's about 3 years old.
03-08-2020 10:28
03-08-2020 10:28
@ClaireWise A warm welcome to our Community! Sorry for the delay in my reply.
Let me help you with your Charge 2 not charging. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves.
Let me know how it goes.
