06-25-2020
05:55
09:24
06-25-2020
05:55
09:24
Since the update earlier this week, my charge 2 won’t sync with other apps and it is struggling to sync even with Fitbit app, although normally gets there after a couple of goes. Only been a problem since the update.
07-05-2020
11:00
09:52
07-05-2020
11:00
09:52
@jhooker6 Welcome to the Fitbit Community!
Let me help you with your Charge 2 not syncing and the issue with other third party apps. For the Charge 2 you can try the following:
Regarding the other apps, your tracker won't sync with them directly. The link is between your Fitbit app and the other apps. Try revoking the access on your settings area and do the same from the other apps side. The relink them as you initially did.
Let me know how it goes.
