04-06-2019
20:30
16:45
04-06-2019
20:30
16:45
The charge 2 isn’t receiving my calls or texts. The notifications just stopped. I turned off & on the notifications & logged out & back in & nothing. Still no notifications
04-07-2019
00:38
12:06
AlvaroFitbit
04-07-2019
00:38
12:06
AlvaroFitbit
When you say you turned notifications on and off, do you mean in the app or on the Charge 2?
A common cause of this is where the Charge 2 is accidentally put into "do not disturb" mode. This is turned on / off by pressing and holding the button on the Charge 2. Could this be the problem here?
04-08-2019 12:08
04-08-2019 12:08
@dazshorty Welcome! It's great to see you around!
I will gladly assist you with notifications on your Charge 2. Besides checking the DND mode that @SteveH I would like to know which phone are you using? Is it compatible? You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on. You can find additional suggestions here.
Let me know how it goes.
