04-08-2019
04:50
16:45
04-08-2019
04:50
16:45
I put it on the charger but it will not go into charging mode. I have tried with the charger plugged into a wall outlet and a USB port on a PC. Is this a charger issue or tracker issue? Thanks for the help.
04-09-2019
06:14
06:19
04-09-2019
06:14
06:19
@Turbo2076 Welcome! It's great to see you around!
I will assist you with your Charge 2 that isn't charging and thank you for trying different ports. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.
Let me know how it goes.
