08-15-2019
04:33
13:47
08-15-2019
04:33
13:47
Anyone else having trouble with the Charge 2 depleting its charge almost immediately. The green light is full on power when I remove it from charger.
Moderator edit: format
08-15-2019 07:48
08-15-2019 07:48
My Charge 2 was holding it's charge for a week until I did the update three days ago. Now it won't even hold a charge for one day or through the night. Ugh!!!
08-15-2019 09:51
08-15-2019 09:51
Mine won't hold a charge for longer than 5 minutes. This started Tuesday afternoon. I hadn't updated the software yet, I was able to yesterday, but it drains immediately after I take it off the charger
08-15-2019 10:07
08-15-2019 10:07
Same here! The light on the back is extremely bright and it seems to be hot as well. 5-10 minutes and done.
Best Answer08-15-2019 10:08
08-15-2019 10:08
Similar issues. Mmmmm... this makes me curious for sure.
08-15-2019 13:53
08-15-2019 13:53
I am having the same issue - charged my Fitbit this morning - received notice Fitbit was low this afternoon.....it use to hold charge for numerous days. I did the update earlier this week. Could update be the issue? Any one hear anything from support at Fitbit?
08-15-2019 17:02
08-15-2019 17:02
I did my update over the weekend and my battery charge indicator has been jacked up since I did it. I've already had a couple of times where my Charge 2 abruptly died just after it had showed I was at 40-50%. I also found when I was charging my Charge 2 right after it had died it claimed that I was fully charged 10 minutes later, which I knew there was no way that could be true since it usually took at least a half hour to fully charge when the battery was low. I definitely think the update is what caused this to happen because my Charge 2 was working great before the update, it was holding a charge for 3-4 days until I got the update.
08-15-2019 21:43
08-15-2019 21:43
I contacted support. We troubleshot and nothing worked. Since my tracker is no longer under warranty, they offered me 25% off of a new one. This is several in a row for me that have not held up to standard (my husband has been through similar issues with another FitBit model), so I am researching Garmin trackers. Maybe look into those as well...
08-16-2019 09:57
08-16-2019 09:57
Since i updated mine with the new firmware it is going from 100% charge to completely drained, unable to even give me a low battery icon, within 5 minutes. I have never had an issue with my fitbit before this update
08-24-2019
20:21
05:21
08-24-2019
20:21
05:21
Hi @CoryIsakson @SueOBI @Lpixie @Pansykim @bballsbest @prolveg, and welcome to the new users in the Community.
Thank you for sharing all this information about your Charge 2 that is no longer holding a charge for too long. Before considering other options, could you please confirm if you already tried all the steps listed in this article?
Also, make sure that you've also tried performing a restart following these steps, then check if you continue to experience the same behavior.
@Lpixie, I'm sorry to see that you continue to experience trouble with the Charge 2 not holding a charge. It is particularly difficult when the device is no longer covered by the warranty, but even tough Support is eager to help with any problem you may experience with the product, they do need to adhere to the official warranty policy, this would start counting from the original date of purchase.
Thank you for taking the time to share your feedback, comments from users are always useful to continue to improving the quality of products and services.
Let me know if you have further questions.
Best Answer09-21-2019 04:33
09-21-2019 04:33
I am having the same issues.
Best Answer09-24-2019 12:04
09-24-2019 12:04
Hello, welcome to the Fitbit Community forums @Leah26. Sorry for the late reply.
Thank you for sharing this information about what you've been experiencing with the Charge 2 and the battery.
Could you please confirm if you already exhausted all the troubleshooting steps listed here previously? They have been useful to other users experiencing something similar with the battery not holding a charge.
Please keep me posted.
09-24-2019 14:26
09-24-2019 14:26
Same for me. Before update, charge would last 7 days. After update, I'm lucky to get 3 days. Makes you wonder...
09-25-2019 06:06
09-25-2019 06:06
My Fitbit Charge 2 is currently holding charge better. I did Dave’s suggestions in article which didn’t help at all. Apple had a IOS update which did make a difference. It seemed like Charge 2 was looking for my iPhone or iPad continually and update fixed the problem of draining Charge 2. I hope this my help others having issue.
Best Answer09-25-2019 08:00
09-25-2019 08:00
My Charge 2 would hold a charge for 5 days, then after I did the Firmware update, now the FitBit is good for almost 24 hours. Come on FitBit! Did you do this on purpose?! Change it back!
Best Answer09-25-2019 08:06
09-25-2019 08:06
I am also loosing power. At first, I had to recharge every 4 days (instead of once a week), but now I'm recharging every other day. If the problem is in the update, why isn't Fitbit fixing it?
Best Answer09-25-2019 08:29
09-25-2019 08:29
Do you have any updates for your phone or computer? Maybe install them and restart your Fitbit. Good luck
Best Answer09-25-2019 08:38
09-25-2019 08:38
None of these helped - pretty generic!! I remember support going the distance back in 2012 when Fitbit was a young company to help customers and not worrying about warranty etc. The firmware did something. - fix it!!! The firmware must not have been compatible with some phones & computers.
09-26-2019 04:20
09-26-2019 04:20
Best Answer09-27-2019 10:19
09-27-2019 10:19
Hello @ScreamMeMeMe @SunsetRunner @cees1 @Leah26, thank you for sharing all this information and welcome to the new users in the Community.
It's good to know that you already tried the suggested steps to improve battery life. I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon.
@Pansykim, thank you for confirming that battery life has improved after the iOS update.
