07-03-2019
14:15
14:54
07-03-2019
14:15
14:54
I have had my Charge 2 for 2 years (I think). At first I did not use the HR sensor due to battery drainage. Recently I started to. But it fails to record specific sleep stage data. It records total sleep time (and waking and restlesness) but never has recorded sleep data. I have no idea why.
07-04-2019 10:33
07-04-2019 10:33
@mmeisler Welcome! It's great to see you around!
Let me help you with your sleep stages data. You may not get them for the following reasons:
I suggest you clean the back of your device with cotton and rubbing alcohol and restart it. Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
Let me know how it goes.
Best Answer07-04-2019 19:24
07-04-2019 19:24
Best Answer07-04-2019 19:25
07-04-2019 19:25
Been there done that. I have read the instructions or wouldn't have posted the question. Since I see large number of people with the same problem I am just assuming it I'd the device and there is nothing to do.
