04-23-2020
22:25
09:49
04-23-2020
22:25
09:49
Hi I have a charge 2 and I cannot change the time or date and it won't sync with any of my devices . I do not have a dongle like they show either . Thanks
05-05-2020 12:55
05-05-2020 12:55
@sunsetrunner I hope you're doing well! Sorry for the delay in my reply.
Let me help you with your Charge 2 not syncing so you haven't been able to update the time and date. You can try the following:
Let me know how it goes.
Best Answer08-06-2020 03:33
08-06-2020 03:33
How do you restart your device
10:34
07:11
08-12-2020
10:34
07:11
@Madyn Welcome to the Fitbit Community! It's great to have you here!
Thank you for your inquiry. You can find the instructions to restart your tracker in my previous post by clicking on the link there.
Keep me posted.
Best Answer08-13-2020 16:10
08-13-2020 16:10
Best Answer08-15-2020 20:31
08-15-2020 20:31
I lost 8 minutes on my Charger 2 (In other words, the time on my Charger 2 is 8 minutes behind the correct time). How do I reset the time to the correct time?
12:54
07:11
08-25-2020
12:54
07:11
@bigalp It's good that the community is growing!
Let me help you with your Charge 2 not showing the correct time. Please try the suggestions in my previous posts as it will help with your tracker's syncing and once it syncs the time should correct itself.
@Madyn happy to hear that the suggestions helped you resolved the issue.
Keep me posted.
Best Answer08-25-2020 14:13
08-25-2020 14:13
I have the same problem and I cannot fix it, even if I followed the steps you indicated.
I cannot connect my Charge 2 with my phone (Android).
I remonved the watch from the app, and try to reset it. I go up to the step when I can enter the 4 numbers appearing on the watch, then nothing happen and the app ask to check the bluetooth settings etc. to see if there is a problem. I don't know what to do to fix it.
Thanks for your help!
