Charge 2 not syncing
Have Fitbit Charge HR 2
Have been in the VA Hospital since November. Cannot sync or update fit bit after charging. Still says June 10, 2019.
how do I reset it it. Won’t let me pick my fit bit to sync
Moderator Edit: Clarified subject and removed personal information
2 REPLIES 2
@jackkeg It's great to see you in the Community!
Let me help you with your Charge 2 not syncing. Make sure that your tracker is setup on your account. After this try the following:
  1. Go to your phone's bluetooth settings and remove all devices listed there.
  2. Restart your phone and restart your device
  3. Check that no battery saving app/feature on your phone is affecting your Fitbit app.
  4. Also, on an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
  5. You can find troubleshooting instructions here.
Let me know how it goes.
Alvaro | Community Moderator
Mine is having the same issue except mine suddenly stopped syncing out of nowhere. I've rebooted my watch and my phone and it still won't sync.
