02-26-2020
13:42
10:23
02-26-2020
13:42
10:23
I have a CHARGE 2 .. .. It does not seem to track my sleep patterns very well. I usually sleep 4 hours at a time then wake and stay awake for couple hours then go back to sleep or nap later in the day depending on time of day / things I need to do. The CHARGE 2 does not seem to track my sleep ( The reason I wore/ bought the FIT BIT was to track sleep.) I do not want to write in nap every time I take one
Does one of the other styles of FIT BIT do a better job at tracking sleep?
03-01-2020
08:58
06:20
03-01-2020
08:58
06:20
@Nonnie88 Welcome to the Fitbit Community! It's great to have you here! Sorry for the delay in my reply.
Let me help you with your sleep detection. Your device will start recording sleep after it detects an hour of inactivity. If you have a light sleep or move too much then this may difficult your sleep detection. Additionally you can try wearing your device on your non dominant hand to decrease the amount of movement it is subjected to. Finally you can restart your device. You can also manually log your sleep time. You can read more about sleep detection here. This will apply to all Fitbit devices so try my suggestions first before looking for an alternative.
Let me know how it goes.
