12-31-2018
02:11
05:01
AlvaroFitbit
12-31-2018
02:11
05:01
AlvaroFitbit
The only real tool we have to try when our fitbit misbehaves is a restart:
If this doesn't kick it back into life then it's probably best to contact customer support via contact.fitbit.com If they can't fix it then they can check your warranty status and advise on your options.
@DiDiX Welcome! Thanks for being part of our Community! Sorry to hear that your Charge 2 isn't working. Adding to the instructions @SteveH shared you can try cleaning the contacts including using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this restart your device and see how it behaves.
Let me know how it goes!
@DiDiX thank you for your update. Happy to hear that the restart helped you fix the issue and thank you so much for posting this as it may help other members in the same situation.
I'll be around!
