12-20-2018
21:16
18:22
12-20-2018
21:16
18:22
I just received my 2nd replacement Fitbit charge 2, the first one
worked but only for a few months than stopped syncing and sending notifications to me. Than I was sent a replacement again and it will restart and vibrate like it’s charging but no battery shows up just the set up link that takes you to the app. It won’t sync or set up my replacement like it should! I keep having these problems and it’s rather annoying having to keep going through this process again and again...
12-20-2018 21:29
12-20-2018 21:29
I have the second replacement and it still won’t sync or charge or set up
12-21-2018 03:51
12-21-2018 03:51
I am having exactly the same issue. 2nd replacement just arrived, the screen comes on with the Fitbit setup link but neither my iPad nor my galaxy S9 can find it on Bluetooth.
can anyone help?
12-21-2018 06:57
12-21-2018 06:57
Hey guys, @RhygK, @Averagedad and @Twtyntwty, let me give you a warm welcome to the Community! I appreciate the time you have taken to try different tips to set up your Charge 2. There is something that I'd like you to make sure, could you please "forget the device" from the Bluetooth settings of your phone/tablet? That will the connection of your new Charge 2, easier. Then repeat the set up process.
Let me know how it goes!
Best Answer12-21-2018 08:36
12-21-2018 08:36
That doesn't resolve the problem of the replacement not charging. It sits in the charge cradle and will vibrate to let you know it is there - but the screen only shows the setup screen - I've had it sitting in the charger overnight - no green lights on the back - and still the setup screen! It won't display the 4 digit code either - and it won't reboot
12-21-2018 08:46
12-21-2018 08:46
I can’t get the lights to work on my replacement either!
12-21-2018 08:55
12-21-2018 08:55
That still does not cover the problem with the replacement pebble not charging. I had the replacement pebble charging overnight on the charger - no green lights on the back - and still on setup screen. when you sit it in the charger it vibrates to let you know its on there right, but it won't hold a charge (no green lights on the back). the screen will not display the 4 digit code to pair the device to the app.
12-21-2018 12:09
12-21-2018 12:09
I’ve got exactly the same problem. I’ve deleted my old device (it had a cracked screen so got a replacement) but this new one won’t sync. I tried the old one and it recognises that one no problem. This is really annoying.
12-21-2018 12:53
12-21-2018 12:53
I’ve just received my new pebble and having the same problem.
I have removed the old charge but won’t ouck up in Bluetooth or Fitbit app. Just shows set up screen
12-21-2018 12:56
12-21-2018 12:56
12-21-2018 15:01
12-21-2018 15:01
Best Answer12-22-2018 00:30
12-22-2018 00:30
Been told it’s a battery issue and I have to return it. Watch this space!
Best Answer12-27-2018 15:12
12-27-2018 15:12
Im having the same issue, received a replacement charge 2 and it does not sync to anything. None of my phones or my iPad can find it. It just comes up with the setup screen. I’ve tried everything. Nothing changes. It seems to be an judging from the posts on here it seems to be an issue recently with the replacement charge 2
12-28-2018 05:44
12-28-2018 05:44
I have the same problem, waiting for the 3rd replacement, infinite cylce of receiving defective pebbles...
12-30-2018 04:55
12-30-2018 04:55
12-30-2018 07:37
12-30-2018 07:37
12-31-2018 00:30
12-31-2018 00:30
Thank you for the update. I hope this works. They just keep telling me to be patient, but they can’t give me s date that it will work.
I’m quite lost without mine and need it for my qualification. I wish I could send the thing back rather than be “patient” because no one even knows what’s going on or if it will even work 🤷:male_sign:
12-31-2018 00:45
12-31-2018 00:45
Best Answer12-31-2018 01:44
12-31-2018 01:44
Best Answer12-31-2018 01:52
12-31-2018 01:52
