04-01-2019
03:04
16:45
04-01-2019
03:04
16:45
Today for some reason there is no map of my run or splits for times. Anyone else having issues. Plus just had to log back in even though I never log out
@Lel45 I hope you're doing well!
I will gladly assist you with this. Did you use the Connected GPS feature to record your run? Did the phone connected with your tracker during the activity? You can try refreshing the link between them by going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on. You can find additional suggestions here.
Let me know how it goes.
