07-03-2018
08:18
18:22
07-03-2018
08:18
18:22
My Charge2 has gone a bit wobbly! ![]()
The screen just cycles from one screen to another. Sometimes it rests at the BPM screen for a while, then it starts to say Notifications ON before showing Notifications OFF and then it goes to something new. The screen stays active like this until the battery is depleted. I recharge it and the same thing happens.
The button on the side seems to function normally and I have reset the watch with no improvement.
HELP!
09-25-2018 01:30 - edited 09-25-2018 01:37
07-03-2018 08:45 - edited 07-03-2018 08:46
Welcome to the Fitbit Community @Tom_McQ! Thanks for already taking the time to troubleshoot this inconvenience with your screen on your own, nice way to go!
In order for me to move forward, can you please let me know since when you started noticing this behavior on your Charge 2? Have you changed or made something different recently on your tracker?
I know you've restarted your device, but please confirm to me if the steps below were attempted correctly in order to perform the restart:
Looking forward to your response!
07-31-2018 10:44
07-31-2018 10:44
My charge 2 had the exact same problem, I did all the steps above, but nothing changes. Nothing seems to help. Please, give me something that somves this!
07-31-2018 11:13
07-31-2018 11:13
Hey there @CarolineDR, thanks for jumping in here and following my tips and recommendations! Since this sounds a bit more serious, I have reached out to our support team and created a case regarding your inquiry. Someone will be reaching out to you within the next 24-72 hours with next steps. ![]()
Point me out if there's anything else I can do for you in the meantime.
Best Answer07-31-2018 16:31
07-31-2018 16:31
My Charge HE just started doing the same thing. It flipped through each screen and now keeps starting and stopping exercises without me pressing anything
Best Answer07-31-2018 16:59
07-31-2018 16:59
it sounds like everyone is having the same or a similar problem as what is being discussed at https://community.fitbit.com/t5/Charge-2/Charge-2-screen-keeps-scrolling/m-p/2865635#M170887.
Unfortunately, the only thing support can seemingly do for you is to either offer a replacement or a discount, and they only seem to do this if your device is still under warranty. Support has said that they Fitbit doesn't have a repair center, so there's no way to fix this problem. If you're device is out of warranty, they'll probably provide you with a link where you can buy a new Fitbit.
Best Answer07-31-2018 18:11
07-31-2018 18:11
My Charge 2 just begin to do the same thing. I'm at work and will retry resetting when I get home. Seems like the only solution is to purchase a new one🤔😣😭
Best Answer09-14-2018 10:00
09-14-2018 10:00
I was just sitting at the computer and out of no where my fitbit charge 2 strated going crazy. If the advise posted doesn't work there is no way I am going buy a new one. Forget that!
09-16-2018 11:15
09-16-2018 11:15
@Tamara613 It's great to see that you've visited the Fitbit Community! Sorry to hear about the issues with your Charge 2. Did you try the suggested troubleshoots? Did they worked for your tracker?
I look forward to your reply!
09-16-2018 13:31
09-16-2018 13:31
My charge 2 is doing the same as all these other people the notifications keeps flipping off and on with the vibration. I have tried everything you all have told me to do. I got my Fitbit for Christmas 2017 so it hasn’t been a year yet. I’m really lost without it. It still records my activity but it I can’t stand the vibration all the time. Please help.
09-17-2018 12:26
09-17-2018 12:26
@Bsgh It's great to see that you've visited the Fitbit Community! Sorry to hear that your tracker is continuously vibrating and for the delay in my response. Thank you for following the suggestions in this thread. Since these haven't worked I suggest you let our Support team know about the issue. I noticed that you already contacted them so I wanted to know if they were able to help you?
Best Answer09-17-2018 14:08
09-17-2018 14:08
Best Answer09-17-2018 14:24
09-17-2018 14:24
Best Answer09-18-2018 07:12
09-18-2018 07:12
@Tamara613 I haven't created a ticket for you only for @Bsgh. I ask if you have tried the restart and other tips in this thread? Please try them and let me know.
@Bsgh really happy to hear that Support was able to help you! Hopefully you are back on track and reaching your fitness goals.
Best Answer09-18-2018 07:15
09-18-2018 07:15
09-18-2018 07:30
09-18-2018 07:30
@LeannaW thank you for the update. Support will try to help you but they are limited by the Warranty period. Still they do try to offer options but it is up to them to see what they may have available for you. Regardless of using a Fitbit or not I do hope you continue your daily efforts to reach your fitness goals.
I'll be around!
Best Answer09-18-2018 11:27
09-18-2018 11:27
My fitbit has also started to do this today. Very disheartened to hear there's no fix.
09-18-2018 12:00
09-18-2018 12:00
@Gengenie It's great to see that you've visited the Fitbit Community! Sorry to hear about your Charge 2 misbehaving. I suggest you try the suggestions in this thread before losing hope. If the issue persist please let me know.
Best Answer09-18-2018 12:34
09-18-2018 12:34
Best Answer09-18-2018 12:46
09-18-2018 12:46
