10-30-2016
23:45
11:39
10-30-2016
23:45
11:39
Hello everyone just wondering if anyone has had issues with the screen, i woke up and saw mine has a big deep scratch and totally bizarre unknown how! Ive been careful and vigilant of it and most certain hasnt hit or touched anything as its on my wrist and i would have felt it. Ive been told its a weak screen but this is dissapointing only had it 4 weeks. Totally puts me of it now
10-03-2018 10:21
10-03-2018 10:21
10-17-2018 06:45
10-17-2018 06:45
I've just joined this club too! A vertical crack running down almost the entire screen has just appeared on my Charge 2. It's just 3 months old.
No evidence of any impact damage and no scratches, so I share the suspicions of others in this club that there is an intrinsic defect. I look forward to convincing Customer Service of that!
By the way , I see that this topic is deemed "solved". How on earth can that be, given that no viable solution has been provided?!
10-17-2018 07:08
10-17-2018 07:08
10-17-2018 07:21
10-17-2018 07:21
10-17-2018 08:20
10-17-2018 08:20
10-17-2018 19:33
10-17-2018 19:33
10-17-2018 20:50 - last edited on 02-14-2020 17:42 by LiliyaFitbit
Perhaps it’s wishful thinking on the part of the company?
From my iPad
10-24-2018 05:27
10-24-2018 05:27
Well... all credit to the Fitbit service folk. They accepted my report of a cracked screen without any fuss, were helpful and polite, and agreed to replace the device under warranty (it is only three months old).
The replacement has arrived today, so Thank you Fitbit folk!
10-24-2018 05:55
10-24-2018 05:55
10-24-2018 05:56
10-24-2018 05:56
You might want to double check the warranty on the replacement. I was told it was only 1 month so when my replacement screen cracked after a few months I was out of luck.
10-24-2018 13:27
10-24-2018 13:27
10-24-2018 14:08
10-24-2018 14:08
10-25-2018 12:40
10-25-2018 12:40
10-29-2018 09:43
10-29-2018 09:43
my Fitbit charge 2 glass screen is cracked how to replace it?
10-29-2018 12:34
10-29-2018 12:34
From what I have read on the forum, the screen can't be repaired. However, it does seem that the Fitbit company are willing to replace a tracker if it is still under guarantee. At least that was my experience.
You should contact the Fitbit Customer Service from inside the Fitbit app (go into your account settings, choose Help and then Contact Customer Service). They will provide you with a case number and will then have to send a photo of the screen accompanied by the case number..
Once they had accepted my claim I received a new tracker in a few days (just the module, no bracelet or charger).
Hope that helps.
10-30-2018 02:23
10-30-2018 02:23
11-02-2018 17:08
11-02-2018 17:08
I've had charge 2 for almost two years and it just spontaneously cracked vertically down the face - no impact. Spoke with fitbit online and they will not cover it since it only has a one year warranty. They offered me 25% off most of their trackers, but 40% off the ionic. They know it is an issue, that the face is defective but are not willing to stand behind their products. This was my third and last fitbit - so disappointed in them. There are many other good fitness trackers.
11-20-2018 19:41
11-20-2018 19:41
My screen did the same thing. I have figured out that when I bend my wrist it puts pressure on the back of the unit which is transferred through the unit to the screen from the inside. Thus resulting in a crack down the side. I continued to wear it and there is now a crack on the other side as well. They run parallel the length of the unit and correspond perfectly with the outer edge of the raised portion on the back of the unit. Obviously a design flaw. I bought the extended warranty with mine but honestly haven't had the time to mess with fighting for a replacement. Should I?
11-20-2018 19:43
11-20-2018 19:43
11-20-2018 23:46
11-20-2018 23:46
