02-07-2018
21:33
18:54
02-07-2018
21:33
18:54
Mundy charge 2 keeps cycling through the screens like I am pushing the button on the side. Ideas?
02-07-2018 22:29
02-07-2018 22:29
Mine is doing the same thing. Plus it went from 100% battery to 65% in under 2 hours because of this.
02-12-2019 06:51
02-12-2019 06:51
Mine also started doing this about 2 weeks ago. Cycles from screen to screen and kills the battery.
02-18-2019 07:01
02-18-2019 07:01
@Bryandshaw @Terri-T @Helmfast Welcome! It's nice to have you on board! Sorry to hear that your Charge 2 is cycling through the menu items. You can clean the button area with cotton and rubbing alcohol. After this use compressed air at a distance to clear the area. Finally restart your device.
Let me know how it goes!
Best Answer08-06-2019 08:45
08-06-2019 08:45
Suggested solution appears to work but then unit reverts to interminable scrolling after 5-10 mins. Been through procedure twice and integrated another suggestion that you reset the unit at least three times. We’ll see but I can’t say I’m hopeful.
Best Answer08-06-2019 08:49
08-06-2019 08:49
Nope, second go lasted 5 mins. Given that this seems to be a known issue, it’s surprising that it’s not been sorted or units recalled.
