07-15-2020
02:33
09:14
07-15-2020
02:33
09:14
My fitbit keeps dying randomly and showing the fitbit logo and the numbers 22:58:00 under it. There doesn't seems to be reason why it is happening. Has anyone ever had this?
07-19-2020
12:33
09:25
07-19-2020
12:33
09:25
@Hpowell10 Welcome to the Community.
Let me help you with your Charge 2 showing a code. What you are seeing is the firmware version of your device which is the latest one. I suggest you try restarting your tracker by following these instructions.
Let me know how it goes.
07-20-2020 19:18
07-20-2020 19:18
My fit bit worked fine until this afternoon, when that code appeared. After restarting my fit bit, per your instructions, now it still shows code but also www.fitbit.com/setup.
09:41
09:25
07-21-2020
09:41
09:25
@Jordan3-1 Welcome to the Fitbit Community! It's great to have you here!
Let me help you with your Charge 2 showing the setup page. If this is the case then you will need to set it up again. I suggest you clear the link between your phone and your tracker before the setup by doing the following:
Best Answer07-21-2020 13:39
07-21-2020 13:39
07:42
09:34
07-30-2020
07:42
09:34
@Jordan3-1 thank you for the update.
Really happy to hear that your tracker is working fine and thank you for confirming that these instructions worked for you as it may help other members in the Community.
I'll be around.
