10-08-2019
02:20
12:16
10-08-2019
02:20
12:16
My Charge 2 was working fine (a year old) . Last night I went to charge it. As soon as I placed it on the charger, it went black. No buzz, no green light. My app says "no device found". I updated the software 2 days ago. Not sure if that has anything' to do with it. TIA for your help.
10-09-2019
06:25
06:43
10-09-2019
06:25
06:43
@Dwn73 Welcome to the Fitbit Community! I hope you're doing well!
Let me help you with your Charge 2 not responding. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.You can also find additional suggestions here.
Let me know how it goes.
