04-08-2019
13:23
16:45
04-08-2019
13:23
16:45
My Fitbit Charge’s battery wont charge. I put it on the charger Saturday morning it read 100% & after a couple of hours it showed a picture of the battery with an exclamation mark in it & it won’t do anything
04-09-2019 06:55
04-09-2019 06:55
@DiDiX It's great to see that you've visited the Fitbit Community!
I will assist you with your Charge 2 not charging. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
Let me know how it goes.
