12-02-2016 19:47 - last edited on 09-09-2020 10:26 by MatthewFitbit
For the last week my charge 2has refused to sync. The app is set to always connected and all day sync. I have reset the tracker several times in the charger. I have turned my phone on and off, turned the Bluetooth on and off, logged out and back into the app, force stopped the app and reopened. Nothing has worked. I get no error message so I'm assuming it can "see" the tracker.
What else can I do?
02-10-2018 04:25
02-10-2018 04:25
No offence but how is this an accepted soliution? I shouldn't have to restart the phone, restart Bluetooth and so on just to sync with the device. I never used to.
The last few weeks the Charge 2 won't track walks because it says there is no connection to the app. I paid a lot of money for this device and it should work better than it is.
02-10-2018 05:27
02-10-2018 05:27
My fitbit has never been good at tracking my unit. And it has not synced since 4th January. Its only 9 months old, I feel that is disgraceful for such a costly item. For your company to release such an Under-proven item for sale is shameful.
Regards Robert Mass.
02-10-2018 06:57
02-10-2018 06:57
02-11-2018 06:04
02-11-2018 06:04
Charge 2 still not syncing properly, the only way to get it to sync on my laptop windows 10, is if I sync it manually on my samsung phone first........why is this happening as it didn't used to? Why is this marked as solved when it clearly isn't and I know I am not the only one having the same issues and why has noone from FItbit addressed any of the issues on here? Seriously?!?!?!
02-11-2018 07:33
02-11-2018 07:33
02-11-2018 09:20
02-11-2018 09:20
Well the reason I started to sync it with my phone is because it stopped working on my laptop. I did only have it on my laptop originally.
02-21-2018 18:52
02-21-2018 18:52
Thanks for this, after years I ran into the same problem. Fixed.
02-21-2018 19:36
02-21-2018 19:36
02-22-2018 04:18
02-22-2018 04:18
Can you share how you fixed it? Was it with the earlier suggestions on this page? TIA
02-22-2018 06:39
02-22-2018 06:39
02-22-2018 18:12
02-22-2018 18:12
02-23-2018 02:44
02-23-2018 02:44
Thank you!! This might be the answer. Appreciated!
02-25-2018 10:20
02-25-2018 10:20
How do you reset your Fitbit? I tried turning the Bluetooth off and on but so far nothing
02-25-2018 10:57
02-25-2018 10:57
after taking the Fitbit app off my phone ( I am now only using my PC) and turning my Bluetooth off and on next I plugged in the Fitbit dongle .It still doesnt recognize my Fitbit and still wont sync... Help! It was working so well then suddenly yesterday it wouldn't sync
02-25-2018 11:13
02-25-2018 11:13
03-05-2018 05:34
03-05-2018 05:34
Updating the app to the latest version did the trick for me just now!
03-05-2018 05:41
03-05-2018 05:41
6 days with Charge 2 - everything fine - today it will not sync
03-05-2018 23:36
03-05-2018 23:36
I've started using an app called Bluetooth Reboot by Justin Mockler. I add a widget next to the Fitbit app and press reboot each time I am going to track a walk.
What makes this app different is it silently restarts Bluetooth, if you do it manually you get the dialogue screen to connect to devices.
We shouldn't have to resort to this type of thing but it seem we do.
I did get a reply in another thread that my phone, a Samsung Galaxy A5 2017, isn't listed as being compatible with my Charge 2 so there is no guarantee they will work together. I find that unbelievable!
03-06-2018 02:56
03-06-2018 02:56
03-06-2018 08:03
03-06-2018 08:03
