07-06-2019
10:40
14:54
07-06-2019
10:40
14:54
The battery died the other night; I recharged; device shows it's 100% charged; counting steps; date is correct; time is wrong (hours and minutes). Time zone is correct on account. I've restarted several times, nothing works. Advice? TIA.
07-07-2019 10:23
07-07-2019 10:23
@mopapa, welcome to the Fitbit Community! It's great to have you here!
Let me help you with the time on your Charge 2. Which phone are you using? Is it compatible? You can try the following:
Once it syncs the time should get updated.
Let me know how it goes.
07-07-2019 11:01
07-07-2019 11:01
try turn off bluetooth, then turn it back on and sync, or restart your device, or log your account out on your fitbit app, or reset your fitbit.
i hope this has helped you.
Best Answer07-07-2019 12:07
07-07-2019 12:07
Thank you. I was trying to sync it with my laptop and it just wouldn't work. I didn't even think about trying with the phone. Did that and now it's got the correct time. Thank you!
07-07-2019 12:07
Thank you so much! I really appreciate your help!
