06-26-2017
20:41
09:26
06-26-2017
20:41
09:26
Midway through a walk tonight, my Fitbit went black and will not power on. It was charged and has been working fine. I tried putting it on the the charging cable and powering it up or reseting it but had no luck. My app shows it is fully charged but of course will not sync because it has no power. Help please
07-20-2019 08:55
07-20-2019 08:55
Best Answer07-20-2019 09:10
07-20-2019 09:10
Thanks Flossie. I’m afraid mine was just over 2 years old by never abused or got wet no luck with the replacement. Fitbit are very hard to contact and don’t seem to care about their existing customers only want to sell more and more Fitbits
Best Answer07-20-2019 09:49
07-20-2019 09:49
Best Answer07-26-2019 11:10
07-26-2019 11:10
I had this same issue, tried the "restart/reset" that all the threads before had suggested, with no luck. I was on the verge of purchasing a new one and decided to buy a new charger first. Not only was the charger bad, the outlet/USB plug wall adapter was too. New charger did the trick, charged the tracker and now all is good.
Best Answer07-26-2019 18:11
07-26-2019 18:11
mine won't turn on but it still buzzes as if it is?
Best Answer07-29-2019 17:12
07-29-2019 17:12
Thank you so much! This was a lifesaver!!
Best Answer07-30-2019 09:03 - last edited on 02-23-2020 17:29 by LiliyaFitbit
Hi! I just contacted fitbit and they were very kind and sent me a new one
for free. Hope you have the same luck!!
Best Answer09-12-2019 20:17
09-12-2019 20:17
I had it charging and I went to turn it on It won't turn on anymore I tried the methods and nothing is happening it hasn't been charged in a couple months and it is about 2 or 3 years old plz help me.
09-13-2019 13:52
09-13-2019 13:52
Best Answer09-25-2019 08:13
09-25-2019 08:13
How do you contact Fitbit? My Charge 2 had the blank screen, although it synched with my phone and recorded steps. The reset worked for me, BUT then it died completely and no amount of trying can reset it 😞
09-29-2019 11:45
09-29-2019 11:45
Thank you! I just tried this and it worked❤️
Best Answer10-10-2019 13:04
10-10-2019 13:04
I just updated my iPhone and haven’t used my Fitbit in a few months. Have it to a friend who tried to set it up on their phone only for the Fitbit not syncing and now it’s black screen. Green lights are flashing but won’t vibrate or turn on when on the charger
Best Answer12-15-2019 05:34
12-15-2019 05:34
My fitbit won't charge I bought a new cable and it still won't work - it doesn't do anything any advice?
Best Answer12-31-2019 11:34
12-31-2019 11:34
I'm having the same issue and was told to clean off the contacts on the watch and charger, which I did. It still did not work after holding in the button while connected to charger and USB port. I was told warranty expired and i need a new one and was extended a discount.
how do they know it's not the charger wire itself?
Best Answer12-31-2019 15:04
12-31-2019 15:04
Best Answer01-02-2020 12:23
01-02-2020 12:23
I just got off the phone with Fitbit customer service agent (Mario). We tried to reset my charge 2. Hold down the button for 15 secs while charging cable is plugged in. Still my charge 2 will not power on after many tries. Agent said warranty expired (few days after 2 year) and all he can do is offered 25% for a new device. I told him I can't trust Fitbit it the device only lasted 2 years. There's nothing they can do about it. Very disappointed with Fitbit. I am going to return this device (to Costco) today.
No more Fitbit ever.
01-02-2020 12:33
01-02-2020 12:33
Best Answer01-29-2020 08:18
01-29-2020 08:18
I had this same problem. When I first tried resetting it didn’t work. I gave up, and left my Charge 2 plugged into the charger.
Decided to try to reset it again a few days later, and I thought it was still not working. I opened the app and it synced with my Charge 2. The screen was still black, and no green lights. I noticed there was an update for the Charge 2, and updated mine. Now it’s working again!😊
Best Answer02-05-2020 05:03
02-05-2020 05:03
Yes it will work because I lost my charger for a year and It started working a little while after it was on the charger.
Best Answer02-18-2020 18:05
02-18-2020 18:05
This isn't working. What do I do now?
