12-16-2018
19:19
14:31
12-16-2018
19:19
14:31
Have had a Charge 3 for about 2 months and have already had more issues with it than the entire time I used my Charge 2. What is Fitbit doing to address the ongoing issues we all seem to be having. Definitely wouldn't recommend that anyone purchase a Charge 3.
My Charge 3 Fitbit stopped working. It won't come on anymore. It vibrates when I push the button, but nothing else. I tried restarting to no avail. This long restart did not work for me either. I received my fitbit last Christmas as a present. I have been enjoying it, but I am pretty bummed now. I will try to call customer service in the next few days.
I think so... I told them when it as purchased based on the dat on the receipt but didn’t have to send it in as a proof or anything. Good luck!
Best AnswerI have replaced mine three times from Costco. I'm done with the Charge 3 I have no confidence in this product. I was told by Fitbit that the Charge 3 is not compatible with my three year old phone.
Hi Alejandra
My fitbit charge 3 after 9 months don’t show the clock when I rotate my hand
Kindly
Leonidas
16:50
04:20
JuanJoFitbit
08-16-2019
16:50
04:20
JuanJoFitbit
I am on 3rd Fit bit in 3 months with this charge 3. I never had any problems with the charge 2. There is a battery problem with the charge 3, they don't charge. I would much rather go back to the charge 2.
I never had any problem with my charge 2, but that's not the case with the charge 3, I am going on my 3rd replacement with the charge 3 as the battery won't re-charge. It's a bad design so if you are going to buy one stick with the charge 2.
Moderator edit: merged reply
20:16
04:21
JuanJoFitbit
08-16-2019
20:16
04:21
JuanJoFitbit
Same here. On 4th one since Christmas and they are definitely not waterproof.
It's definitely not waterproof...at least not the 3 of mine that have quit after being in the water.
Get Outlook for Android
I have exactly the same issues. Did anybody get a solution for that problem?
it is really annoying especially when you want to rely on the time and it won't show the correct one because the watch also doesn't work properly.
Best AnswerI have a blank screen on my new charge 3. I have tried the 15 second reset and get nothing. Some vibrations from the watch. It seems lots of people have the same problem. Please help
