Charge 3 Not Syncing
My Charge 3 won't sync anymore - have tried re-booting it and pressing on the side for 8 seconds as suggested, but nothing works.  Also turning bluetooth on and off.  Next step is to throw it out of an upstairs window as it's so frustrating lol.   If I delete the app and re-start it again will I lose all my data, or are there any other suggestions?  Thanks.
33 REPLIES 33
Mine stopped syncing after a software update on my iPhone - it won't connect via bluetooth any more. Fortunately, it still syncs with my iPad, which I haven't updated. I don't think deleting and reinstalling the app will delete all your data - just the steps you have accrued since your last sync. You could also try deleting and reinstalling you Charge 3.
Hilary | UK
Charge, Aria, iPhone 4s, Mac
If this answer is helpful, please vote for it and/or mark it as a solution.
Thanks for your advice. My iPhone did have an update last weekend - the Fitbit did work for a short while after that, then stopped. Will try deleting and re-installing the Charge 3.
I have tried but it still doesn't work.
So annoying! Will keep trying different things and let you know if I have any success.
Mine started doing this last week. It started by losing half an hour every night and stopped recording my sleeping info. I had to reboot it to correct the time every morning. Now I can't get it to sync at all, (last sync was the 16th) and it doesn't even function as a watch anymore. I miss my old Fitbit.
The good news is that I finally managed to get mine syncing again! I clicked on 'Forget my Device' on Bluetooth and then set it up again. It still didn't work, so on my Fitbit I went to Settings / Options and clicked on Reboot (you don't lose data). It then synced straight away. Good luck, hope it works for you all!
I use iPad and iPhone apps, both keep disconnecting the Charge3 from Bluetooth, why?
I have done that twice, it’s a pain, something should be done!
Having the same problem. My last sync was on the 13th. I’ve restarted while charging, rebooted from the device, restarted my phone, reinstalled the app. Nothing. My phone says it can’t connect to the device via Bluetooth but the app is still able to tell me what battery percentage I have.
My charge 3 stopped syncing on 16th May. Tried rebooting, switching phone on and off and Bluetooth as well but no luck. This happened last week as well as didnt sync fod 3 days then synced on 16th. So sick of it thinking of throwing it out of the window
I’m having the same problem, and have also tried all the things you mentioned, except the last one. Where is”Reboot” in Settings? I’m not seeing it. (Might be blinded by my frustration...🙃
Thanks for starting this thread. Thought it was just me. Will try forget device and reboot.
I got it to behave.  I forgot the Charge 3 in Bluetooth, reopened my Fitbit app and it immediately asked to pair my phone and the Charge 3. Go figure. Ah, sweet success. Thanks folks.
Definitely!
If you find settings (under weather), click on it then scroll down to 'About'. Click on that then scroll down to 'Reboot device'. Hope it works!
Sorry, that should be Settings then About.  Too excited about finally sorting it lol.
 I don't know I'm afraid as not an expert.  Hope you get it sorted.
I feel your pain.  I had to do the Bluetooth bit first, then reboot before it would work.
So pleased for you - know how frustrating it is.  Was so happy when mine suddenly started working again!
