10-09-2018
03:51
15:47
10-09-2018
03:51
15:47
14 floors so far today. Same problem as Versa by the looks of it🙁 Only walked up 1 small flight of stairs.
Moderator Edit: Updated Subject for Clarity
10-26-2018 00:41
10-26-2018 00:41
hey @SantiR just made a 60-floors trip yesterday according to charge 3.
actually it was 4-5.
how can we fix it?
10-26-2018 13:10
10-26-2018 13:10
10-29-2018 15:31
10-29-2018 15:31
Hello everyone! Thanks for your continuous participation on this thread regarding the high amount of floors climbed recorded by your Charge 3. Thanks for sharing the details about the experience you are having.
Fitbit is currently aware of it, but may not be able to provide a fix in the immediate future. We'll continue to monitor the situation, and keep our team informed of the impact to you and other customers. We understand that this isn't the resolution you're hoping for, but rest assured we're always working to improve our products.
Also, you may be experiencing this as a result of some environmental factors. Check my post for more details on this.
There is a way to erase those floor. Check the workaround here to give it a try.
I appreciate your patience and look forward to getting you back on track.
Keep me posted!
10-30-2018 01:40
10-30-2018 01:40
10-30-2018 14:15
10-30-2018 14:15
@godshoneybunny Thanks for your reply and for providing your feedback regarding the workaround! I'm glad you have found DriveBit to be helpful for this situation. It is easier to use this app, indeed.
I'm sure a lot of users will find this helpful. Thanks for sharing!
Also, take a look at the Discussions Board as you will find a lot of interesting things there. Feel free to post on any thread you want. If you are looking for Fitbit friends to compete with on challenges, check this thread to add some!
See you around!
11-08-2018 15:30
11-08-2018 15:30
I was at Costco to to buy the charge 3.
i wanted it for the water proof feature.
i check the forum to see if it tracks steps as their display does not mention it as a function.
After read this this thread true I’m goin to pass on the 3 and stick with my hr till this is resolved.
11-13-2018 12:00 - edited 11-13-2018 12:21
Drove 46 miles today, mostly on the motorway, during which time my Charge 3 registered 55 floors! It also recorded my car journey as an outdoor bike ride!
On a positive note I earned my first lighthouse badge!
11-13-2018 12:12
11-13-2018 12:12
Been using an Apple Watch for the past 2 weeks. After some research and a few apps I have a full Fitbit replacement which is much more accurate and more consistent. Battery life of a day is not great, but sadly had to leave Fitbit behind. Too unreliable, inaccurate and the lack of honesty about these problems is just not right.
11-13-2018 12:27
11-13-2018 12:27
Yep, same issue. Just earned the skyscraper badge (100 floors in a day). I’m in FL and I have to work to get 1 floor a day. Didn’t have this problem with the Blaze. The floors feature on the charge 3 is basically useless.
11-14-2018 07:25 - edited 11-14-2018 07:26
@JonoS2 Probably you drove too slow. 😉
11-14-2018 07:49
11-14-2018 07:49
Same thing is happening to me! It told me I walked 27 flights the other day and I do not walk up any stairs at all. My battery life also dies very quickly
11-29-2018 18:20
11-29-2018 18:20
I just got my Charge 3 a few days ago. I have done ZERO stairs and it counts them when I'm driving, sitting still, and walking. It's annoying, my inexpensive fit tracker did a MUCH better job. I've disappointed. It also gives me TONS of steps when DRIVING
11-29-2018 18:38
11-29-2018 18:38
Same here. To me floors is a useless data point since it can't be trusted... might as well take it out and clean up the clutter on the dashboard
12-30-2018 21:58
12-30-2018 21:58
The workaround doesn't work!! I am showing floors climbed when I am actually walking. If I use the workaround it deletes all activity not just the floors climbed. Quite frankly fitbits response that this cannot be fixed quickly is just not good enough given that this does not happen with the Charge 2. Surely it's the same software with improvements???
12-31-2018 12:35
12-31-2018 12:35
Same problem in FL where my route is flat. Walk the same 5 miles daily and normally 1 floor. Today 41!!!
01-07-2019 19:24
01-07-2019 19:24
Huge bummer. My charge 2 was spot on counting floors. Wish I never ‘upgraded’. I can’t even compete with my coworkers anymore because they all feel my data is skewed. It is! Pity. Must be a hardware issue since the moderator is skirting the issue.
01-12-2019 12:04
01-12-2019 12:04
Hello all - I also had this issue, but was able to resolve it. I found two causes:
1) A defective device
2) An aftermarket band
My Charge 3 (with an aftermarket band) was recording about 10 times the correct amount of floors. After battling with support, I decided to exchange it. I wore the new Charge 3 with the stock band for about a week and it was working perfectly - problem resolved!
Then I put the aftermarket band back on and it started overcounting floors again. Not nearly as bad a before, maybe double the correct amount, but still noticeably more than it should.
I suspect that there maybe a batch of bad Charge 3s out there that need to be recalled.
01-12-2019 12:20
01-12-2019 12:20
Can’t believe that an aftermarket band can affect it to be honest. How is that even possible? As for a bad batch, I have not seen one that doesn’t over count floors yet.
01-12-2019 12:37
01-12-2019 12:37
01-12-2019 17:00
