11-15-2020
12:17
10:13
11-15-2020
12:17
10:13
hello community, recent issues with chatge 3, battery fully charged holds a minute then seems empty.
when put in charger again looks 1% and then in about a minute looks like 100 again.
and same goes on and on.
tried:
reboot (many time)
change different usb source for charging
tried to even delete and add a new device
cleaned the who charger and fitbit
not working...
so what now?
11-16-2020 03:16
11-16-2020 03:16
@BaraBBB It's great to see that you've visited the Fitbit Community!
Let me help you with your Charge 3 not holding a charge and thank you for troubleshooting this issue. Since the issue persists I have created a ticket so our Support team can further assist you via email.
Let me know how it goes.
Best Answer11-16-2020 05:27
11-16-2020 05:27
I’m having the same issue with my fitbit. It’s battery drains within an 1-4 hours and vibrates until it’s put on charge (mostly in the middle of the night). It also is taking longer to charge. I’ve reset it multiple times, still having the same issue.
My fitbit has stopped alerting me when my phone is ringing and messages come through. I have reset Bluetooth and notification settings and it’s hasn’t helped.
06:27
07:21
11-16-2020
06:27
07:21
@Shantelle456 I hope you're doing well!
Let me help you with your Charge 3 not holding a charge and not syncing. For the battery draining quickly try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. You can follow these instructions to help improve the battery life.
Regarding the syncing issues please follow these instructions.
11-16-2020 16:12
11-16-2020 16:12
Thank you. I did both things you suggested and it is working again. Thank you so much!!
Best Answer11-17-2020 05:12
11-17-2020 05:12
Ok so the Fitbit is still running out of battery fast. It only lasted 12 hours and then started vibrating until put on charge.
Best Answer11-17-2020 10:33
11-17-2020 10:33
I have been experiencing the exact same problem for a couple of days now. I also tried all those steps, but nothing seems to work. After max. 5 minutes (most of the time after only 1-2 minutes) the same problem arises.
Best Answer11-23-2020 04:15
11-23-2020 04:15
I tried all these suggestions and some helped for a little while, making the battery last 12 hours and then 3 days but now it’s gone straight back to only lasting at most 30mins. I’ve re-done everything you suggested but it hasn’t helped.
Best Answer11-24-2020 12:19
11-24-2020 12:19
problem solved
