01-02-2020
18:37
15:40
01-02-2020
18:37
15:40
The issue happened out of the blue. I got it completely charged to 100%. Ready to use. I went to work, check the watch to see the time and the watch is completely dead. The battery charge goes back down to 1%. I’ve tried troubleshooting it and nothing. It is still working. It just wouldn’t stay on. What should I do?
01-03-2020
04:19
07:49
01-03-2020
04:19
07:49
Welcome to the Community, @shwirls.
Thanks for troubleshooting this battery issue. If your tracker isn't holding a charge, I recommend taking a look at the help article: Can I extend my Fitbit device's battery life? and follow the tips provided there. After following them, test the unit.
Let me know the outcome.
04:19
07:49
01-03-2020
04:19
07:49
Best Answer01-21-2020 07:02
01-21-2020 07:02
@AlejandraFitbit It doesn’t have a problem with extending the battery life. The watch just dies completely within a minute or less after charging it to100%. It doesn’t stay on longer than 2 minutes.
01-22-2020
08:05
07:49
01-22-2020
08:05
07:49
Thanks for the update, @shwirls.
Since the instructions provided didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
In the meantime, let me know if you need anything else.
Best Answer05-31-2020 04:07
05-31-2020 04:07
I have the same issue. I have it for more than 1 year now, it went from lasting 7 days to last a couple of hours or less. I also tried all the advised troubleshooting to no effect. It's currently loading but it's even worse now: after shutting it off 3 times in a row as advised, it now is stuck loading at 4%. It does not even load further anymore. And I have been using it without any alarms or any other feature other than recording my exercise, heartbeat and sleep. No shower with it either. And I live in a moderate weather country, so not extreme heat or cold. I don't know what else to do.
Best Answer05-31-2020 04:08
05-31-2020 04:08
I tried all this and nothing works for me anymore. What else can I do?
Best Answer12-15-2020 09:30
12-15-2020 09:30
I have the same issue on my 1st charge 3 and then my replacement charge 3. But because they don't extend warranty on the replacement, it puts me 2 months past the original purchase date 😡. All they will offer is 30% discount on a new item
11:12
07:48
12-15-2020
11:12
07:48
@shwirls Welcome to the Community.
Sorry to hear about this. Support does follow the guidelines described in the warranty so if your device is outside the warranty period they won't be able to replace it. This is why they offer a discount to help customers in this situation. Still thank you for sharing your feedback.
I'll be around.
