11-07-2020
08:22
12:57
11-07-2020
08:22
12:57
Please help.... My Fitbit battery died. I charged the battery, now the only thing that will come up on the screen is a smiley face. I have tried all the restart options with no luck. What can I do?
11-08-2020
09:13
10:01
11-08-2020
09:13
10:01
@Mutsch Welcome to the Fitbit Community!
Let me help you with your Charge 3 not working and thank you for restarting your tracker. Since the issue persists I have created a ticket so our Support team can further assist you via email.
Let me know how it goes.
Best Answer11-08-2020 10:05
11-08-2020 10:05
Alvaro my screen won’t turn on as well. Not even the smiley face
11-09-2020
05:56
10:01
11-09-2020
05:56
10:01
@justin2144 I hope you're doing well!
Let me help you with your Charge 3. When you refer to the smiley face do you mean you have tried a restart on your device? I just want to confirm that you have tried the following:
I look forward to your reply.
Best Answer11-09-2020 07:12
11-09-2020 07:12
I am having a similar problem. My charge 3 screen will go black (or very very dim), and the only way to get it to come back is to plug it in to the charger and press the side button. When it goes dead, the green lights on the underside are also off. This is happening several times per day, regardless of battery level. The button on the side of the device will also not work half the time, and when the device is plugged in, the watch will vibrate almost constantly (like I am pressing that side button).
It seems like this has all happened since I did the software update, and the battery life has dwindled from once weekly charge, to once every day or two in that same time period
11-09-2020 12:09
11-09-2020 12:09
11-10-2020
12:03
10:02
11-10-2020
12:03
10:02
@ryanmhik Thanks for joining us!
Thank you for providing all this information. Did you try the restart already stated in my previous post? This is before we can continue with the process.
@justin2144 I noticed that you already have a ticket with our Support team so keep working with them to find a solution.
Best Answer11-10-2020 13:34
11-10-2020 13:34
@AlvaroFitbit , yes I have reset the device several times. In the last day or two, the battery seems to be draining incredibly fast (charged it overnight, it stated 91%, wore it until 11:30 this morning and it was down to 6%). I reset it and charged it recently, and have been wearing it for 30 minutes and it is down to 75% battery (from 100%).
when the device is fully charged, I notice some black horizontal lines on the display as well (areas where the white display is not working)
Best Answer11-10-2020 13:46
11-10-2020 13:46
My charge 3 has a black screen and won't charge anymore. It vibrated for about 60 seconds and then it was dead and hasn't come back to life again.
Best Answer11-10-2020 15:22
11-10-2020 15:22
I have the same issue.
I have tried multiple resets.
Holding the side button it just vibrates.
At one point it came back with a smiley face then still went to a blank screen.
11-10-2020 15:37
11-10-2020 15:37
me too! Mine does absolutely nothing.
11-10-2020 16:14
11-10-2020 16:14
Greetings, I too have just encountered exactly what Justin describes, but I did get partial pixels at one point. My tracking lights illuminate properly, the device tracks and syncs correctly, and changing the watch face did not work either. I have tried multiple times to reset it via the cable and do not get even the smiley face. However, it does seem to vibrate as if it was resetting. I have otherwise never had a problem with my device. This seems unusually suspicious considering people are now suddenly posting about this identical issue. What was pushed to the devices recently?
11-10-2020 18:30
11-10-2020 18:30
Me too. What is going on. Tried changing the clock face several times and the 8 second tip. No joy 😢
11-10-2020 18:44
11-10-2020 18:44
I have the same problem.. Blank,black screen..
Best Answer11-10-2020 21:23
11-10-2020 21:23
Alvaro I’ve been having the same issue with a blank screen and no smiley face. Started last week. Black screen and only the green light. I do see that it is still tracking my activity via the app. I’ve tried all the reset steps here and the 15 sec hold and unplug from USB with no luck. What should I do next?
09:27
08:07
11-12-2020
09:27
08:07
@Christywc @DenB_CO @coastalhues @Cjrey9964 @polemicmario It's good that the community is growing!
@Christywc @Darbie12 you don't mention any troubleshoots so please confirm that you have tried the restart explained in my previous post and also make sure that your tracker isn't in the sleep mode by long pressing the button. @polemicmario since your tracker is still syncing I suggest you try changing the clock face.
@coastalhues thank you for mentioning that you troubleshooted this issue. I have created a ticket so our Support team can further assist you via email.
@ryanmhik @DenB_CO @Cjrey9964 I noticed that you already have tickets with our Support team so keep working with them to find a solution.
Best Answer11-12-2020 12:12
11-12-2020 12:12
Hi Alvaro,
I’m having these same problems as well - started yesterday. I’ve tried all the above reset solutions you’ve mentioned after charging up my Fitbit up however I cannot get it to bring up the smiley face let alone any other screen. Yes I get the vibrations and yes it’s still feeding info to the dashboard but no display on device face at all!
Best Answer11-12-2020 12:22
11-12-2020 12:22
I reset my charge. Push on left side button. Swiped left while wearing my watch until it came to Settings. Brightness somehow was changed to “dim” I tapped it until it was “normal”
went back to being bright
Best Answer11-12-2020 12:39
11-12-2020 12:39
Best Answer11-12-2020 13:16
11-12-2020 13:16
My charge 3 has the same problem & more. Two days ago the screen went black; the battery is holding a charge & Fitbit is still synced to my phone, but now some of the recorded data is way off (i.e. I walk for 10 min & it says 500 min, though the distance shown is correct).
I have tried the 8-second & 15-second reset, but the screen stays black & the data is still wrong.
Please, is there anything else I can try?
I love using Fitbit, but this is my 2nd to malfunction in less than 2 years! I doubt that I’ll purchase another, since the odds are that it won’t last long. ☹️
