11-28-2020
23:44
09:38
AlvaroFitbit
11-28-2020
23:44
09:38
AlvaroFitbit
Last week my Charge 3 screen went black although it still vibrates and tracks steps. I tried all the troubleshooting steps without success and after contacting customer service I was told that my Charge 3 is not under warranty so I pulled out my Alta HR (which was only replaced because I received the Charge 3 as a gift). I charged the Alta HR and followed the set up process on the app without problem, however a few hours later the screen on the Alta HR also went black! It seems to me that if the black screen is a consistent problem across multiple Fitbit devices then there must be a software issue. In case it matters, I am using the Galaxy S9 to sync devices.
I am really frustrated that I have had 2 Fitbit devices go from working perfectly to being completely useless in less than a week without any reason or user error. I am curious if anyone else has experienced similar issues. There's no way I'm buying a new Fitbit device just to have it join the graveyard of black screens.
11-29-2020
09:56
10:47
11-29-2020
09:56
10:47
@ToriB21 Welcome to the Fitbit Community! It's great to have you here.
Sorry to hear about your unresponsive Charge 3 and Alta HR. Since you already troubleshooted the Charge 3 with Support I suggest you restart your Alta HR (if you haven't done so) by following these instructions.
Let me know how it goes.
Best Answer@AlvaroFitbit Thank you for your suggestion! I tried restarting my Alta HR and it vibrated, but nothing else happened.
11:17
10:47
12-01-2020
11:17
10:47
@ToriB21 thank you for the reply.
Since the issue persists the remaining step is to let our Support team know about this. I noticed that you have a recent ticket so you can let them know that both devices are being affected and see if they have any options for this.
Keep me posted.
