01-19-2019
21:03
13:05
01-19-2019
21:03
13:05
My Charge 3 just has a black/blank screen and won't do anything at all. I placed it on the charger thinking it was dead. It gave it's little vibrate signifying the charger was placed properly, and a smiley face appeared as though I rebooted. The smiley face stays on for about 8-10 seconds and then just goes back to black screen and will do nothing else. I tried a reboot, but nothing happened. I then removed it from the charger and re-attempted a couple of more times with the same results. I also have tried connected the charging cable both through a usb charger and my computer just to see if plugging it into the computer would jumpstart it somehow. The same results no matter where I try. I have left it on the charger for quite awhile now, and still just a black screen. Did it just completely fail on me? What else can I try? I have searched here, and I don't seem to find any answers. Thanks!
07-08-2021
05:51
07:05
07-08-2021
05:51
07:05
@sushmas Thank you for your reply.
I understand how you are feeling and I appreciate the feedback provided. Regarding your question, I'd like to let you know that replacement devices are provided for products that are within the warranty period.
If your original Charge 3 is no longer under warranty a discount could be an available option but some conditions and requirements should be met. For more information about our warranty policy, I recommend visiting the following link: https://www.fitbit.com/global/us/legal/returns-and-warranty.
See you around.
01-20-2019 00:44
01-20-2019 00:44
There is only one more thing to try before you contact Support (link in my signature) - a long restart
CHARGE 3 LONG RESTART
Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button. Note: Device won't have a smiley face icon and should be off with a black screen. Remove the device from the charging cable. Plug the device into the charging cable again. The smiley face icon appears on the screen.
Helen | Western Australia
01-20-2019 01:45
01-20-2019 01:45
Just tried what you suggested Nellyg and it worked thank you so much
05-21-2019 09:43
05-21-2019 09:43
I also tried as well and it still won't work.
I rebooted it since it didn't sync with my phone. Then it went all black, I still get vibration but no screen.
I did all the things you said with the charger and then I see a smiley face, but when it goes away it still won't do anything.
I don't know what to do now
05-23-2019 07:37
05-23-2019 07:37
Welcome on board @Manouk23, it's nice to see you around! Thanks for trying the troubleshooting steps recommended here in order to solve the issue with your Charge 3's screen.
Since the suggestions did not work, I went ahead and created a case for you with our Support Team. Someone will reach out to you soon to offer their assistance. Please keep a lookout in your inbox to the email address associated with this account.
Please let me know if there's anything else I may do to assist you in the meantime.
07-11-2019 13:27
07-11-2019 13:27
My fitbit 3 just went to a black screen. I purchased less then 6 months ago.
I have researched what to do and nothing seems to working.
Steps I have completed:
Plugged directly into USB port on computer held button down to reset.
Disconnected then reconnect held power button down until I see a line then a smiley face.
Removed and back to blank screen.
Any other ideas?
07-11-2019 14:46
07-11-2019 14:46
07-17-2019 11:11
07-17-2019 11:11
Mine is doing the same thing. I reboot using the 15 second technique described. The smiley face comes on and then the screen goes black the moment I disconnect it from the charger. Still vibrates but screen is black.
Please help!
01-18-2020 20:32
01-18-2020 20:32
Mine has been like this for two weeks now. It has done it before and the reset worked. This time, it is just black screen, smiley cones up for a bit, then back to black. Not even letting me do the reset. This is my second charge 3 in less than two years.
01-19-2020 03:10
01-19-2020 03:10
Hi,
my fit bit 3 has been fine since I did the routine of changing the clock face, plugging in and holding the start button for 15 seconds disconnecting and putting it back on charge mode ( via mains) and holding start button again for second time. This worked for me but there is obviously a problem with some f the Fitbit 3 out there as this is a very common fault. I hope you get it sorted.
05-28-2020 11:48
05-28-2020 11:48
I tried this twice & vibrates- I get the smiley face Which is faint at the end but still a black screen.
05-29-2020 15:26
05-29-2020 15:26
05-29-2020 19:12
05-29-2020 19:12
05-29-2020 19:53
05-29-2020 19:53
Hi there,
I am also having the same issue. A few days ago I had this happen and then reset and got the smiley face and it worked fine. Then this morning it went blank again and I have tried all the techniques listed for rebooting but am still not able to get the screen to work.
Can you please advise as to next steps? Thank you!
05-29-2020 21:56
05-29-2020 21:56
I’ve gone through all the steps multiple times and my screen remains black. No smiley face. No nothin’. It vibrates when I push the button and it syncs with my phone—just no display.
05-31-2020 00:32
05-31-2020 00:32
10-08-2020 20:10
10-08-2020 20:10
I have been having the same issues for a couple of months now. I've tried the 15 sec restart plugged into a laptop and a direct power source. Neither work. I've held the button down, unplugged, replugged, and repeated and nothing. There is nothing on the screen. No smiley face, or battery sign, or anything. My phone won't sync with it (the fitbit app is updated), so I can't even change the clock face. It's less than a year old. For a product that costs more than $100 I expect more. How do I fix this? Nothing suggested on any of the related pages works.
04-11-2021 04:23
04-11-2021 04:23
am getting the exact same thing. fitbit went a bit goofy by vibrating and bouncing screens with not response. So I rebooted. It started back up and worked for about an hour. then went goofy again. this time I did a hard reboot and did the 15 seconds,. now it just gives me a smiley face and goes black after a little bit., won't sync. the battery life is good. I am pretty sure it is dead or dying. I am going to open a ticket and ask for a replace. I love this thing when it works!!
04-11-2021
18:00
11:07
JuanJoFitbit
04-11-2021
18:00
11:07
JuanJoFitbit
Same problem with mine too!!
Thanks. Waiting for your email.
Need a solution please
Moderator edit: merged reply
07-01-2021 14:40
07-01-2021 14:40
Did anyone solve this issue, I’m about to give up and purchase something else. I’ve done all the rebooting both short and long, changed clock face several times and still blank screen, syncs ok and works but no point having it on my wrist if I can’t even look at the time.
