10-01-2020 10:25 - last edited on 10-04-2020 16:37 by
I am unable to see my screen. I have reset the fitbit and barely saw the smiley face. After several attempts I give up. Please help me.
10-02-2020 14:52 - edited 06-21-2024 11:14
Hi there @Mink2005, welcome to the Community Forums. I'm sorry to hear that your Charge 3's screen went blank, I understand where your concern is coming from. Thanks for already trying to fix your tracker prior to posting here. I'll be glad to continue to help you.
In order for me to better assist you with this, please confirm that you've followed the steps below:
I'm looking forward to your response, keep me posted.
Best Answer10-02-2020 14:52 - edited 06-21-2024 11:14
Best Answer10-02-2020 16:39
10-02-2020 16:39
Check screen brightness isn’t set to dim in settings and that your screen is not in sleep mode
06:47
06:56
10-03-2020
06:47
06:56
It is working now
Moderator Edit: Personal info removed
Best Answer10-03-2020 06:57
10-03-2020 06:57
How do you check screen brightness and sleep mode? I don't see those in settings for Charge 3
10-03-2020 06:57 - edited 02-24-2024 10:30
Hi there @Mink2005, thanks for getting back and for the update. I'm glad to hear that your Charge 3's screen is working now. 😉
Hello @Trigg0711, thanks for stopping by and for helping out!
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
Hi @SunsetRunner, welcome to the Community Forums. For more information about the Sleep mode and Brightness settings on your Charge 3, see: How do I navigate my Fitbit device?
Let me know if you have any questions present.
Best Answer10-03-2020 07:20
10-03-2020 07:20
I have tried all of those steps and my screen is still blank. What's next?
10-03-2020 07:38
10-03-2020 07:38
That doesn't help me as I CANNOT see my screen
10-03-2020 19:31
10-03-2020 19:31
Fitbit 3 is a piece of junk and this iis the most convoluted forum I have ever seen.
Only simple answers and useless answers
Same with the alta.all feel good tech support
10-10-2020 00:32
10-10-2020 00:32
Hi, my fitbit charge 3 now has a blank screen. I've tried to restart it, that hasn't worked. I've also changed the clock face, that also hasn't worked. The screen is totally blank. No smiley face when resetting just black. I've had this less than a year. Any ideas on how to get screen to work?
01-31-2021 20:22
01-31-2021 20:22
Hi, similar problem, all above steps do not work but i'll break it down. Cannot reset (8 or 15 seconds or longer), no smiley face, didn't restart, will not show anything on screen, updated phone software update + fitbit update, changed clockface on phone app but still completely black screen that vibrates. Please don't reply with the standard "make sure you do reset as described here or change the clockface". Nothing works and I can fix any of my household technology, meaning I believe this is a bug with the tech, recieved as a christmas present 2 years ago. Still counts steps but does not function as a watch or any display at all.
03-10-2021 09:05
03-10-2021 09:05
i have exactly the same issue, spoke to fit bit customer services. not interested as now 2 yrs old very disappointing for such a large company. cant see me buying another
03-10-2021 10:21
03-10-2021 10:21
Hi
I tried everything that was recommended to fix black screen on my Charge 3 but I didn't work. I called costumer support and they assisted me doing the same steps they mentioned in the forum. I didn't work either. They send me an email later apologizing for not being able to fix my problem and to let me know that my tracker was out of warranty already, since it was almost 2 years that I got it. So, they offered me a coupon 35% discount to use it to buy another device. Do you think I am going to do it? No. I am really disappointed with the company. It seems that they just use costumers to make money and offer a warranty to cover the expectancy functionality of the device which I strongly believe, they know anticipately that devices will not be working more than 2 years. I feel sorry for the still costumers that believe in this company.
03-11-2021 13:45
03-11-2021 13:45
I've been through this drill several times and still came up with a blank screen. I finally figured out that if I went into a dark room or closet I could dimly make out the screen. I swiped to get to the last menu Settings, tapped Brightness and set to Auto. Voila!
08-29-2021 17:03
08-29-2021 17:03
OK, folks. I have the same problem. I can't see anything on my screen. I have tried resetting it and can't get the smiley face (or can't see it). It does vibrate occasionally and I can sync it. I can't change settings I can't see! Help!
04:32
07:20
08-30-2021
04:32
07:20
Hello everyone. @btwalters Welcome to the community forums.
I appreciate your help in trying to resolve this matter. It seems that you've also followed the recommended tips in this thread and since the inconvenience has persisted, my best recommendation is that you please reach out to our Support Team for further assistance.
Note that you can contact them through the link provided in the thread or you can click here to get connected. Also, take into consideration that you can contact them through chat or over the phone, but phone wait times are longer than normal, so I recommend initiating a chat.
Please make sure to provide a brief explanation of the inconvenience and mention the troubleshooting steps you've followed, this way they can assist you from there.
10-28-2021 05:12
10-28-2021 05:12
I have the same problem. Blank screen but still recording activity. No amount of resetting, changes of clock face works. When the screen started fading I was able to find the brightness setting and increase it a little, but still wasn’t as it had been originally. Even this has now faded to nothing. It can’t be a coincidence so many people have this issue. LED fault?? It was a gift 2 years ago. Is this a classic case of built-in obsolescence? It stops working so you are forced to buy a newer model? Not impressed!
10-28-2021 06:38
10-28-2021 06:38
10-29-2021
11:10
11:13
10-29-2021
11:10
11:13
@Willsharon @Pennine123 I hope you're doing well.
Sorry to hear about this and thank you for troubleshooting this issue. Since the issue persists I suggest you contact our Support team for further assistance. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
@Pennine123 before you purchase any new device always reach out to our Support team so see which options they may have for you.
Hope this helps.
Best Answer10-29-2021 19:05
10-29-2021 19:05
Hi, my Charge 3 kept doing that repeatedly. I would get a magnifying glass and flashlight to try to see the figures on the screen. "Sometimes" I was fast enough to see the thing had switched to "sleep" mode. Then I could switch it back to "wake up." But it seemed to go dim every time after a charge. Then most recently it went completely blank. No amount of thumping or restarting made it light up. However, it was still vibrating, and the green light flashed. I called support. She had me reset the clock face on the app on the computer; that made no difference. She had me do a "long" restart -- which was the same as the restarts I had been doing, but I held the button for 15 seconds. Still no luck. She said I needed to get a new Charge; this one was nonfunctioning.
Soooo I decided to poke a pin into the tiny hole on the back of the Fitbit. I had nothing to lose, right? Ironically, it vibrated and lit up! Now it will light up when I hit the side button, but not when I thump on it. Not sure how much longer that will work; I haven't put it back on a charge yet. But I ordered a replacement Charge 3 on eBay. I don't want all the gizmos of the Charge 5, and I want to be able to count stairs -- a feature not available on the new models. I just need a simple tracker for steps and stairs, so I'll keep trying to find and use old Charge 3's. This one lasted almost 3 years.
